Hello all,
I'm trying to get an EPICS test app going on RTEMS on an
MVME5500 board, and I'm encountering a problem when trying to get files from a
TFTP server.
"Can't open /TFTP/10.80.60.112/epics/mvme5500/st.cmd:
I/O error"
My TFTP server logs don't show any attempt at this
connection.
I'm using RTEMS 4.10 and EPICS 3.14.12. I am building the
apps with the -DOMIT_NFS_SUPPORT flag set in a MINGW environment on a Windows 7
machine with RTEMS-mvme5500 set as the target arch.
I am also able to download that file (and others) from the
tftp server while still in the MOTLOAD prompt on the mvme board.
I have the following GEVs set on the mvme board:
mot-/dev/enet1-cipa=10.80.60.142
mot-/dev/enet1-sipa=10.80.60.112
mot-/dev/enet1-snma=255.255.0.0
mot-/dev/enet1-gipa=10.80.60.20
rtems-client-name=mvme5500
epics-script=epics/mvme5500/st.cmd
rtems-dns-server=10.80.60.12
rtems-dns-domainname=pro-dex.com
epics-ntpserver=71.245.107.83
The networking when the application loads seems to be
working fine, as I'm able to get time from the NTP server.
I'm not running a BOOTP server, and so I hardcoded these
network parameters into bsp_driver_config and rtems_bsdnet_config in
rtems_netconfig.c
Any assistance in this problem would be greatly appreciated.
Thank you very much.
Jim Eastman
This e-mail and any attachment(s) are from Pro-Dex, Inc. and may contain information that is confidential or privileged. If you are not the intended recipient, do not read, copy or distribute the e-mail or any attachments. Instead, please notify the sender at the phone number indicated above and delete the e-mail and any attachments. Thank you.
