Hi, Andrew and all;
> The latest non-experimental released version of the sequencer is 2.0.
12, which
> does build with 3.14.12.
It's just that I wasn't aware of it. I've tried sncseq-2.0.12 with
base-3.14.12. I've built it without any problems. I'd like to thank
all of you who kindly let me know with rapid responses.
Thank you very much!
Jun-ichi
----- Original Message -----
> Hi,
> On Tuesday 11 January 2011 23:56:33 [email protected] wrote:
> > I tried to build seq-2.0.11 with base-3.14.12 on CentOS 5.5 to
> > find that it fails. (I attatch the log messages below this writing.)
> > It looks like the problem is something under base/configure though
> > I'm not sure on this point.
12, which
> If you prefer to modify your 2.0.11 installation though, you will need
to
> remove all mention of the iocsh library from the src/seq/Makefile — it
was
> merged into libCom in Base 3.14.10. Under src/snc/Makefile you should
also
> remove the lines setting SYS_PROD_LIBS_Linux and SYS_PROD_LIBS_DEFAULT.
There
> were some other changes between 2.0.11 and 2.0.12, but I'm not sure if
they're
> essential; it will probably be quicker to just download 2.0.12.
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he
will
> refuse to believe it. If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence. -- Bertrand Russell
- Building base-3.14.12 for a specific target jun-ichi.odagiri
- Building seq-2.0.11 with base-3.14.12 jun-ichi.odagiri
- Re: Building seq-2.0.11 with base-3.14.12 Andrew Johnson
RE: large arrays native element count wrong with Channel Access in EPICS 3.14.12 Jeff Hill
Re: Errors in building areaDetector Mi Qingru
<2011>
<2011>
