1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Errors in building areaDetector
To: "Mark Rivers" <[email protected]>, "tech-talk epics" <[email protected]>
Date: Thu, 13 Jan 2011 10:38:09 +0800
I did it, and commented "DIRS+=tiffSuppport" in ADApp/Makefile. The building has ended without any errors.
Thank you very much!
Mi Qingru
SSRF
021-33933238
-----原始邮件----- From: Mark Rivers
Sent: Wednesday, January 12, 2011 9:22 PM
To: Mi Qingru ; tech-talk epics
Subject: RE: Errors in building areaDetector
The problem is that Centos4.4 is quite old, from 2006. The versions of libtiff and libjpeg that I distribute with areaDetector are built on a more recent version of Linux, and won't work on that old version.
You can fix the problem by installing versions of libtiff and libjpeg on your system that are compatible with Centos4.4. Then change the Makefile in the marCCDApp to use the system versions of these libraries, rather than the versions included in areaDetector. There are comments in the Makefile that explain that.
Sent: Wed 1/12/2011 1:01 AM
To: tech-talk epics
Subject: Errors in building areaDetector
I builds areaDetectorR1-6 on CentOS4.4. I have built all support modules such as asyn, sscan. The following are the errors when building areaDetector.
/usr/bin/g++ -o marCCDApp -Wl,-Bstatic -L/BLC/epics/modules/areaDetectorR1-6/lib/linux-x86 -L/BLC/epics/base-3-14-11/lib/linux-x86 -L/BLC/epics/modules/asyn4-13-1/lib/linux-x86 -L/BLC/epics/modules/autosave-4-7/lib/linux-x86 -L/BLC/epics/modules/busy-1-3/lib/linux-x86 -L/BLC/epics/modules/calc-2-8/lib/linux-x86 -L/BLC/epics/modules/mcaR6-12-1/lib/linux-x86 -L/BLC/epics/modules/sscan-2-6-6/lib/linux-x86 -Wl,-rpath,/BLC/epics/modules/areaDetectorR1-6/lib/linux-x86 -Wl,-rpath,/BLC/epics/base-3-14-11/lib/linux-x86 -Wl,-rpath,/BLC/epics/modules/asyn4-13-1/lib/linux-x86 -Wl,-rpath,/BLC/epics/modules/autosave-4-7/lib/linux-x86 -Wl,-rpath,/BLC/epics/modules/busy-1-3/lib/linux-x86 -Wl,-rpath,/BLC/epics/modules/calc-2-8/lib/linux-x86 -Wl,-rpath,/BLC/epics/modules/mcaR6-12-1/lib/linux-x86 -Wl,-rpath,/BLC/epics/modules/sscan-2-6-6/lib/linux-x86 -m32 marCCDApp_registerRecordDeviceDriver.o marCCDAppMain.o -lmarCCD_AD -lNDPlugin -lADBase -lnetCDF -lcalc -lbusy -lsscan -lautosave -lmca -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lPvAPI -lImageLib -lNeXus -lmfhdf -ldf -lhdf5 -lmxml -ltiff -ljpeg -lz -Wl,-Bdynamic -lpthread -lreadline -lncurses -lm -lrt -ldl -lgcc /BLC/epics/modules/areaDetectorR1-6/lib/linux-x86/libtiff.a(tif_dirread.o)(.text+0x210c): In function `TIFFReadDirectory':
: undefined reference to `__stack_chk_fail'
/BLC/epics/modules/areaDetectorR1-6/lib/linux-x86/libtiff.a(tif_dirwrite.o)(.text+0x1b73): In function `_TIFFWriteDirectory':
/BLC/epics/modules/areaDetectorR1-6/lib/linux-x86/libtiff.a(tif_jpeg.o)(.text+0x626): In function `TIFFjpeg_output_message':
/BLC/epics/modules/areaDetectorR1-6/lib/linux-x86/libjpeg.a(jchuff.o)(.text+0x518): In function `jpeg_make_c_derived_tbl':
/BLC/epics/modules/areaDetectorR1-6/lib/linux-x86/libjpeg.a(jchuff.o)(.text+0x9e2): In function `jpeg_gen_optimal_table':
/BLC/epics/modules/areaDetectorR1-6/lib/linux-x86/libjpeg.a(jdmarker.o)(.text+0x94f): more undefined references to `__stack_chk_fail' follow
collect2: ld returned 1 exit status
make[3]: *** [marCCDApp] Error 1
make[3]: Leaving directory `/BLC/epics/modules/areaDetectorR1-6/ADApp/marCCDSrc/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/BLC/epics/modules/areaDetectorR1-6/ADApp/marCCDSrc'
make[1]: *** [marCCDSrc.install] Error 2
make[1]: Leaving directory `/BLC/epics/modules/areaDetectorR1-6/ADApp'
make: *** [ADApp.install]  Error 2
Mi Qingru
SSRF
021-33933238
Errors in building areaDetector Mi Qingru
RE: Errors in building areaDetector Mark Rivers
Prev: Re: Building seq-2.0.11 with base-3.14.12 jun-ichi.odagiri
Next: RE: large arrays native element count wrong with Channel Access inEPICS 3.14.12 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Errors in building areaDetector Mark Rivers
Next: EPICS support for Harvard PHD Ultra syringe pump tom.cobb
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
