1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Firewall (iptables) issues?
To: EPICS Tech Talk <[email protected]>
Date: Fri, 05 Nov 2010 12:36:34 -0400
On 05.11.2010 11:28, Eric Norum wrote:
To summarize:
If you want channel access clients on a machine to be able to see replies to broadcast PV search requests you need to permit inbound UDP packets with source port EPICS_CA_SERVER_PORT (default is 5064).  On systems using iptables this can be accomplished by a rule like
	-A INPUT -s 192.168.0.0/22 -p udp --sport 5064 -j ACCEPT
If you want channel access servers (e.g. "soft IOCs") on a machine to be able to see clients you need to permit inbound TCP and UDP packets with source port EPICS_CA_SERVER_PORT (default is 5064).  On systems using iptables this can be accomplished by rules like
	-A INPUT -s 192.168.0.0/22 -p udp --dport 5064 -j ACCEPT
	-A INPUT -s 192.168.0.0/22 -p tcp --dport 5064 -j ACCEPT
In all cases the "-s 192.168.0.0/22" specifies the range of addresses from which you wish to accept packets.
Don't forget:
If you run caRepeater on a machine, so that your client applications are able to see beacons from IOCs, and can detect connection loss and new IOCs coming online, you need to permit inbound UDP packets with source port EPICS_CA_REPEATER_PORT (default is 5065). On systems using iptables this can be accomplished by a rule like
-A INPUT -s 192.168.0.0/22 -p udp --sport 5065 -j ACCEPT
(Only necessary if your firewall does not allow all outgoing traffic by default:)
If you want channel access servers (e.g. "soft IOCs") on a machine to be able to send beacons, so that their clients can detect connection loss and your IOCs starting up, you need to permit outbound UDP packets with source port EPICS_CA_REPEATER_PORT (default is 5065). On systems using iptables this can be accomplished by a rule like
-A OUTPUT -p udp --dport 5065 -j ACCEPT
Cheers,
Ralph
Firewall (iptables) issues? Eric Norum
Re: Firewall (iptables) issues? Darren S. Dale
Re: Firewall (iptables) issues? Eric Norum
Re: Firewall (iptables) issues? Andrew Johnson
Re: Firewall (iptables) issues? Phillip Sorensen
Prev: Re: base 3-14-11 and breakpoint tables for ai and ao Andrew Johnson
Next: Re: devEtherIP Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Firewall (iptables) issues? Eric Norum
Next: Re: Firewall (iptables) issues? Eric Norum
ANJ, 05 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
