1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Firewall (iptables) issues?
To: [email protected]
Date: Fri, 05 Nov 2010 10:54:45 -0400
On 11/04/2010 12:51 PM, Andrew Johnson wrote:
On Thursday 04 November 2010 11:25:52 Eric Norum wrote:
Thanks.  That does it.
Here's what I now have.
-A RH-Firewall-1-INPUT -s 128.3.128.0/22 -p udp --dport 5064 -j ACCEPT
-A RH-Firewall-1-INPUT -s 128.3.128.0/22 -p udp --dport 5065 -j ACCEPT
-A RH-Firewall-1-INPUT -s 128.3.128.0/22 -p tcp --dport 5064 -j ACCEPT
-A RH-Firewall-1-INPUT -s 128.3.128.0/22 -p tcp --dport 5065 -j ACCEPT
-A RH-Firewall-1-INPUT -s 128.3.128.0/22 -p udp --sport 5064 -j ACCEPT
Maybe this needs to go in either the application developer's guide or the release notes.
Since this is a Channel Access issue I think it makes more sense to put it in
the CA Reference Manual.  Note that the "RH-Firewall-1-INPUT" part is probably
distribution-specific (I suspect the "RH" stands for Red Hat), and there's
also a subnet-specific part to those commands.
Are *all* of those lines really necessary though?  It would be nice to have
something that says "CA clients need ...", "a soft IOC needs ..." etc.
- Andrew
I just have the equivalent last line in my rules, along with the standard accept of established and related traffic. This seems to work
Phil Sorensen
Re: Firewall (iptables) issues? Eric Norum
Re: Firewall (iptables) issues? Darren S. Dale
Re: Firewall (iptables) issues? Andrew Johnson
Prev: Re: base 3-14-11 and breakpoint tables for ai and ao Ralph Lange
Next: Re: Firewall (iptables) issues? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Firewall (iptables) issues? Andrew Johnson
ANJ, 05 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
