1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: devEtherIP
Date: Fri, 05 Nov 2010 14:44:25 -0400
Hello Jeff:
That is a good discovery!
The driver is started when the device support's "init" routine is called
with 'after'=1, to which the app. dev. guide sais:
"This routine is called ... (with 'after'=1) ... after all records are
initialized but before the scan tasks are started".
The issue is that this is the last possible initialization step that a
driver has. The onceQ is initialized in initOnce(), which in turn is called
by scanInit(), which in turn happens _after_ the init(after=1) call to
device support.
For those records that are "Passive" and effectively scanned by changes on
the PLC, I see no better way than what you did to check if maybe the
database isn't ready, yet.
I'll include your changes, inc' the version numbers etc.
Kay
On 11/3/10 16:55 , "Jeff Hill" <[email protected]> wrote:
> All,
> Sometime back I mentioned that LANSCE was experiencing a crash
> in the Allen Bradley TCP/IP PLC driver (devEtherIP). There were some
> maintenance days this week, and I found some time to track down the
> cause. Apparently the following race condition is occurring.
> o iocInit begins
> o device support initialization functions start the drvEtherIP
> auxiliary threads (one for each plc)
> o when a network message comes back from the plc the drvEtherIP
> auxiliary thread calls functions in devEtherIP which call scanOnce.
> o scanOnce tries to use the uninitialized "onceQ" ring buffer,
> and crashes.
> o later, iocInit calls initOnce
> o initOnce creates the "onceQ" ring buffer
> We are experience the bug in R3.13, but looking at the latest
> sourceforge sources I am inclined to suspect that there is also
> a race condition vulnerability when the latest runs under R3.14.
> Below are the patches I made to the driver. Unfortunately, it was
> necessary to create two versions; one for R3.13 and one for R3.14.
> We only run this driver on R3.13 IOC's so I have _not_ tested the R3.14
> version of the fix; Furthermore, the authors of this driver should
> review my fix as they may arrive at a better alternative.
> Index: devEtherIP.c
> RCS file: /epics/cvs/extensions/ab5550/dev/devEtherIP.c,v
> retrieving revision 1.8
> diff -r1.8 devEtherIP.c
> 286a287,302
>> static void etherIP_scanOnce ( void * pRec )
>>       * astonished to discover that initHookRegister is in
>>       * initHooks.h in R3.13, but initHookRegister isnt
>>       * in iocCore object file in R3.13, so we resort
>>       * to an archaic brute force approach
>> #    ifndef HAVE_314_API
>>      while ( ! interruptAccept ) {
>>          epicsThreadSleep  ( 0.1 );
>> #    endif
>>      scanOnce ( pRec );
> 417c433
> <         scanOnce(rec);
>>       etherIP_scanOnce ( rec );
> 469c485
> <         scanOnce(rec);
> 539c555
> <         scanOnce (rec);
> 589c605
> <         scanOnce(rec);
> Index: drvEtherIP.c
> RCS file: /epics/cvs/extensions/ab5550/dev/drvEtherIP.c,v
> retrieving revision 1.6
> diff -r1.6 drvEtherIP.c
> 25a26,27
>> #include "initHooks.h"
> 1295a1298,1301
>> #ifdef HAVE_314_API
>> static int databaseIsReady = false;
>> #endif
> 1308a1315,1320
>> #ifdef HAVE_314_API
>>     if (!databaseIsReady) {
>>        epicsMutexUnlock(drvEtherIP_private.lock);
>>        return 0;
>> #endif
> 1388a1401,1430
>> #ifdef HAVE_314_API
>> void drvEtherIP_initHook ( initHookState state )
>>     if (drvEtherIP_private.lock == 0) return;
>>     if ( state == initHookAfterScanInit ) {
>>         epicsMutexLock(drvEtherIP_private.lock);
>>         databaseIsReady = true;
>>         drvEtherIP_restart();
>> #endif
>> long drvEtherIP_drvInit ()
>>      * in initHooks.h in R3.13, but not in iocCore
>>      * object file in R3.13
>> #ifdef HAVE_314_API
>>     int status = initHookRegister ( drvEtherIP_initHook );
>>     if ( status ) {
>>         errlogPrintf (
>>               "drvEtherIP_drvInit: init hook install failed\n" );
>> #endif
>>     return 0;
> 1394c1436
> <     long (* inie) ();
>>     long (* init) ();
> 1399c1441
> <     NULL
>>     drvEtherIP_drvInit
> Jeff
> ______________________________________________________
> Jeffrey O. Hill           Email        [email protected]
> LANL MS H820              Voice        505 665 1831
> Los Alamos NM 87545 USA   FAX          505 665 5107
> Message content: TSPA
> With sufficient thrust, pigs fly just fine. However, this is
> not necessarily a good idea. It is hard to be sure where they
> are going to land, and it could be dangerous sitting under them
> as they fly overhead. -- RFC 1925
devEtherIP Jeff Hill
Prev: Re: Firewall (iptables) issues? Ralph Lange
Next: Options for reviving old Allen Bradley PLC implementations Chestnut, Ronald P.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: devEtherIP Jeff Hill
Next: Firewall (iptables) issues? Eric Norum
ANJ, 05 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
