1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Firewall (iptables) issues?
To: [email protected]
Date: Thu, 4 Nov 2010 11:51:37 -0500
On Thursday 04 November 2010 11:25:52 Eric Norum wrote:
> Thanks.  That does it.
> Here's what I now have.
> -A RH-Firewall-1-INPUT -s 128.3.128.0/22 -p udp --dport 5064 -j ACCEPT
> -A RH-Firewall-1-INPUT -s 128.3.128.0/22 -p udp --dport 5065 -j ACCEPT
> -A RH-Firewall-1-INPUT -s 128.3.128.0/22 -p tcp --dport 5064 -j ACCEPT
> -A RH-Firewall-1-INPUT -s 128.3.128.0/22 -p tcp --dport 5065 -j ACCEPT
> -A RH-Firewall-1-INPUT -s 128.3.128.0/22 -p udp --sport 5064 -j ACCEPT
> Maybe this needs to go in either the application developer's guide or the
> release notes.
Since this is a Channel Access issue I think it makes more sense to put it in
the CA Reference Manual.  Note that the "RH-Firewall-1-INPUT" part is probably
distribution-specific (I suspect the "RH" stands for Red Hat), and there's
also a subnet-specific part to those commands.
Are *all* of those lines really necessary though?  It would be nice to have
something that says "CA clients need ...", "a soft IOC needs ..." etc.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: Firewall (iptables) issues? Phillip Sorensen
Firewall (iptables) issues? Eric Norum
Re: Firewall (iptables) issues? Darren S. Dale
Re: Firewall (iptables) issues? Eric Norum
Prev: Re: Firewall (iptables) issues? Eric Norum
Next: iOS EPICS Channel Access Pelaia II, Tom
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Firewall (iptables) issues? Phillip Sorensen
ANJ, 05 Nov 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
