1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11
To: Ron Sluiter <[email protected]>
Cc: Jerome HOSSELET <[email protected]>, [email protected]
Date: Mon, 11 Oct 2010 17:38:33 -0400
Ron,
Please consider incorporating something like the following in "motor.h", and do away with the #cpu(xxx) notation (which triggers _a lot_ of compiler warning/noise):
/* Define, from top to bottom, how bit fields are packed. */
/* This works for gnu, SunPro, MS Visual C. */
#if defined(_WIN32) || defined (_M_IX86) || defined (_X86_)
    #define LSB_First (TRUE)  /* LSB is packed first. */
#elif defined (__i386__) || defined(_armv4l_) || defined (_X86_64_) || defined(__ARMEL__)
#elif defined(__sparc__) || defined(__m68k__) || defined (__PPC__) || defined(__ARMEB__)
    #define MSB_First (TRUE)  /* MSB is packed first. */
#else
#error unknown bit order!
#endif
IIRC, the compiler for vxWorks is gnu-based, so you should be able get a list of compiler-provided preprocessor definitions like this:
    djc@TooLBox--> touch /tmp/foo.c
    djc@TooLBox--> gcc -E -dM /tmp/foo.c | less
Thanks.
-- dc
On Mon, Oct 11, 2010 at 3:17 PM, Ron Sluiter <[email protected]> wrote:
Hello Jerome,
I had to make a change to the,
<motor>/motorApp/MotorSrc/motor.h
file in order to successfully compile it for a VxWorks 6.x
target architecture.  I am surprised that you are not getting
a compiler error.
I planned on releasing a minor version update (R6.5.2)
that includes the above change to the motor.h file,
but I have made the motor.h file change available here.
So let us see if that fixes the problems you are experiencing
before I make a new motor record release.
Ron
On 10/11/2010 10:08 AM, Jerome HOSSELET wrote:
Hi all,
I have some troubles with a motor driver v 6.5.1 and EPICS base 3.14.11 and VxWorks 6.8
VxWorks 6.8 : install ok
Base EPICS 3.14.11 : compilation ok
Support motor 6.5.1: compilation ok
I use a MAXv-4000 with a servo configuration (PSM configuration).
When i use a VxWorks 6.7 and motor 6.4.4 and base 3.14.8.2 => all it's ok
but when i move in last release all package it doesn't works.
The home status : ATHM always = 0
During the motion a message appear Motion = "Move"  &&  "Communication error"
When i check my analogic output for motor 1 (commande analogic to the servo)
I probe always 10 V.
It's not normal ......
Ron or other can i help me ?
Jerome HOSSELET
[email protected]
No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Jerome HOSSELET
Re: No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Ron Sluiter
Prev: Re: Timeout errors with ASYN Modbus Driver 2.0 David Dudley
Next: RE: Timeout errors with ASYN Modbus Driver 2.0 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Ron Sluiter
Next: Re: No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Andrew Johnson
ANJ, 12 Oct 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
