Hello Jerome,
I had to make a change to the,
<motor>/motorApp/MotorSrc/motor.h
file in order to successfully compile it for a VxWorks 6.x
target architecture. I am surprised that you are not getting
a compiler error.
I planned on releasing a minor version update (R6.5.2)
that includes the above change to the motor.h file,
but I have made the motor.h file change available
here.
So let us see if that fixes the problems you are experiencing
before I make a new motor record release.
Ron
On 10/11/2010 10:08 AM, Jerome HOSSELET wrote:
Hi all,
I have some troubles with a motor driver v 6.5.1 and EPICS base 3.14.11 and VxWorks 6.8
VxWorks 6.8 : install ok
Base EPICS 3.14.11 : compilation ok
Support motor 6.5.1: compilation ok
I use a MAXv-4000 with a servo configuration (PSM configuration).
When i use a VxWorks 6.7 and motor 6.4.4 and base 3.14.8.2 => all it's ok
but when i move in last release all package it doesn't works.
The home status : ATHM always = 0
During the motion a message appear Motion = "Move" && "Communication error"
When i check my analogic output for motor 1 (commande analogic to the servo)
I probe always 10 V.
It's not normal ......
Ron or other can i help me ?
Jerome HOSSELET
[email protected]
- Re: No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Daron Chabot
- No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Jerome HOSSELET
Timeout errors with ASYN Modbus Driver 2.0 David Dudley
RE: Timeout errors with ASYN Modbus Driver 2.0 Mark Rivers
<2010>
<2010>
ANJ, 11 Oct 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
