I am having issues with MEDM StripTool display. I have four curves on the same StripTool with four different channels. Everything is working fine except I do not see the comments I had given. For example, for curve 0 the comment is as follows: Strip.Curve.0.Comment 4K Coolant Supply The "4K Coolant Supply" does not appear in display, insted I get "analog input record". Also while launching the same StripChart I keep getting the following kind of messages in my terminal: ==== StripTool Xt Warning Handler ==== warning: Name: FilterText Class: XmTextField Character '\160' not supported in font. Discarded. At times I see my given comment for some seconds and even for some minutes before it finally disappears giving "analog input record". Any suggestions how I can get the comments? Sincerely -- Adesh
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
