I have extended EDM to handle the protocol that we have here at Fermilab. This allows me to get values and see them update. When our equivalent of an IOC fails values stop updating and turn white like what EDM does with EPICS' PVs. So far so good. However, when our "IOC" is returned to service the values start updating again (good) but do not turn back to the original non-white color (bad). In one unfortunate case we end up with white on white text. Originally the values did not even update after our "IOC" was returned to service. Thanks to tech-talk I was given the hint to make use of do_conn_state_callbacks() to give EDM connection state information. With the hint I got values to resume updates but not return to non-white. Any hints about what I am missing? Just a reference to the routine within EDM that draws the value on the screen would help speed up my reverse engineering of the API for extend EDM's protocol capablitiies would help, so that I could determine what I need to be doing. Thanks for your time. Sincerely, Carl Schumann
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
