1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: GPIB and Record Advice
To: Eric Norum <[email protected]>
Cc: [email protected]
Date: Sat, 28 Aug 2010 10:26:13 -0700
Thanks again Eric,
Increasing the TIMEOUT to 5 sec reduces the the frequency of this error. As I continue to design the DAQ I'll optimize further.
Cheers,
Andrew
On Aug 27, 2010, at 11:15 AM, Eric Norum wrote:
> It sounds like what is happening is this:
> 1) Record ai_1 begins to process.
> 2) Command for ai_1 is sent.
> 3) Instrument does not reply quickly enough and devGpib times out.
> 4) Record ai_1 finishes processing.
> 5) Record ai_2 begins to process.
> 6) Command for ai_2 is sent.
> 7) Instrument gets confused because it sees a second command before it has replied to the first.
> Try increasing the TIMEOUT value to a larger value.   Perhaps 10 seconds or so?
> On Aug 27, 2010, at 11:01 AM, Andrew Wagner wrote:
>> Hey Mark,
>> My device support includes devGpib.h and was created using a template produced with makeSupport.pl -t devGpib . I then edited the template to include the commands appropriate to my device in the command array. In the startup script, I connect to the device with drvAsynIPPortConfigure, i.e. drvAsynIPPortConfigure("L0","172.25.100.69:1234",0,0,0) . I have 3 passive ai records and 3 calc records that process the ai records every 10 seconds. Each ai record calls device support to talk to the MUX. Periodically the IOC prints the message: read status "172.25.100.69:1234" timeout: Resource temporarily unavailable, and the MUX gets a -410 error. Perhaps if I increase the TIMEOUT or TIMEWINDOW ?
>> Cheers,
>> Andrew
> Eric Norum
> [email protected]
GPIB and Record Advice Andrew Wagner
RE: GPIB and Record Advice Mark Rivers
Re: GPIB and Record Advice Andrew Wagner
Re: GPIB and Record Advice Eric Norum
Prev: EDM: virtual circuit disconnect and reconnect handling Carl Schumann
Next: MEDM StripTool does not show curve comment Adesh Subedi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: GPIB and Record Advice Eric Norum
Next: network video John Dobbins
