Hey Mark,
My device support includes devGpib.h and was created using a template produced with makeSupport.pl -t devGpib . I then edited the template to include the commands appropriate to my device in the command array. In the startup script, I connect to the device with drvAsynIPPortConfigure, i.e. drvAsynIPPortConfigure("L0","172.25.100.69:1234",0,0,0) . I have 3 passive ai records and 3 calc records that process the ai records every 10 seconds. Each ai record calls device support to talk to the MUX. Periodically the IOC prints the message: read status "172.25.100.69:1234" timeout: Resource temporarily unavailable, and the MUX gets a -410 error. Perhaps if I increase the TIMEOUT or TIMEWINDOW ?
Cheers,
Andrew
On Aug 27, 2010, at 6:41 AM, Mark Rivers wrote:
> You did not say what module you used to write your driver. If you use asyn then your driver should call pasynOctetSyncIO->writeRead(). That is guaranteed to be an atomic operation, so a writeRead from another record cannot interfere. If you do write() followed by read() you will have the problems you are describing, because a second write can occur before the first read is issued.
> Are you using devGpib, streamDevice, asynPortDriver, or what?
> Mark
> ________________________________
> From: [email protected] on behalf of Andrew Wagner
> Sent: Fri 8/27/2010 3:03 AM
> To: [email protected]
> Subject: GPIB and Record Advice
> Hey everyone,
> I've created device support and a driver for the Agilent 34970 MUX which I access over Ethernet via the PROLOGIX GPIB-Ethernet controller. I'm currently issuing three measurement commands in succession to read out three temperatures. The problem I run into is that occasionally one readout will not finish before the next is issued resulting in a LINK_INVALID error for the record. The MUX also reports the error -410 (Invalid command issued) when this occurs. Is there a good way to prevent asynchronous records that need to access the same device from "bumping into each other" in this way? If there were only two records I could set SDIS to the PACT of the other record but I have at least 3 and likely more records that need to access the MUX. Thanks very much for your help and advice.
> Andrew Wagner
- Re: GPIB and Record Advice Eric Norum
- GPIB and Record Advice Andrew Wagner
- RE: GPIB and Record Advice Mark Rivers
RE: derived works Jeff Hill
<2010>
<2010>
