Hi All,
I am doing an experiment about global event timing system with
the source code from this website http://epics.svn.sourceforge.net/viewvc/epics/applications/trunk/mrfEventSystem/ ,my
target is mvme5100 and server is RHEL4 with a vxWorks5.5.1 cross-compiler
environment,the hardware is Event Generator 230 and Event Receiver 230.First I
want to use mrfApp application to achieve the basic function of the timing
system,but when loading the startup script,errors occur.It seems that he
record/device support for EVG can't be recognized,while the supports for
EVR are all right.
The error information is :
-> </home/wanglin/timingApp/iocBoot/iocmrf/st.cmd ##
Example vxWorks startup file
## The following is needed if your board support package
doesn't at boot time ## automatically cd to the directory containing its
startup script #cd "/home/wanglin/timingApp/iocBoot/iocmrf"
#< cdCommands #< ../nfsCommands
cd "/home/wanglin/timingApp" value = 0 = 0x0 ## You may
have to change mrf to something else ## everywhere it appears in this
file
ld < bin/vxWorks-ppc604_long/mrfEgLib.munch sysAtReboot
not found. epicsExit will not be called by reboot. value = 518713200 =
0x1eeaef70 ld < bin/vxWorks-ppc604_long/mrfErLib.munch sysAtReboot not
found. epicsExit will not be called by reboot. value = 516383168 =
0x1ec761c0 rebootHookAdd (epicsExitCallAtExits) value = 0 =
0x0
## This drvTS initializer is needed if the IOC has a hardware
event system #TSinit
## Register all support
components dbLoadDatabase("dbd/mrfEg.dbd") value = 0 =
0x0 dbLoadDatabase("dbd/mrfEr.dbd") value = 0 =
0x0 #dbLoadDatabase("dbd/mrfbase.dbd")
mrfEg_registerRecordDeviceDriver(pdbbase) value = 0 =
0x0 mrfEr_registerRecordDeviceDriver(pdbbase) value = 0 = 0x0
## Load record
## Set this to see messages from mySub #mySubDebug =
1
dbLoadRecords("db/csnsEvg.db","SUBSYS=timing, DEVICE=test,
CardNo=3") value = 0 = 0x0 dbLoadRecords("db/csnsEvr.db", "SUBSYS=timing,
DEVICE=test, No=0, PulseWidth=200 ") value = 0 =
0x0 #dbLoadRecords("db/dbExample2.db","user=epics,no=1,scan=1
second") #dbLoadRecords("db/dbExample2.db","user=epics,no=2,scan=2
second") #dbLoadRecords("db/dbExample2.db","user=epics,no=3,scan=5
second")
EgConfigure(0, 3, 0x280000) value = 0 =
0x0 ErConfigureVME(0, 5, 0x300000, 0x62, 4) value = 0 = 0x0
iocInit() Starting
iocInit ############################################################################ ###
EPICS IOC CORE built on Aug 15 2010 ### EPICS R3.14.8.2 $R3-14-8-2$
$2006/01/06
15:55:13$ ############################################################################ iocInit: driver drvMrf200Eg not found iocInit record support
for eg not found iocInit record support for egevent not found device
support devEg not found device support devEgEvent not found missing record
support entry table PV: timing:test:eg dbProcess missing record support entry
table PV: timing:test:egEvt:gunT dbProcess missing record support entry table
PV: timing:test:egEvt:ram0 dbProcess iocInit: All initialization
complete value = 0 = 0x0
## Start any sequence programs #seq
&sncExample,"user=wanglin" -> iocClockSyncWithNTPserver: sntpcTimeGet
errno = 0x710003
dbl timing:test:eg timing:test:egEvt:gunT timing:test:egEvt:ram0 timing:test:er timing:test:erEvt:bkt0 timing:test:erEvt:gunT timing:test:erEvt:kck timing:test:erEvt:kly timing:test:erEvt:ram0 value
= 0 = 0x0 ->
The Makefile in mrfApp/src/ is :
$(TIMING)/mrfApp/src/Makefile # # Author: Eric Bjorklund #
Date: 19 December
2005 # #------------------------------------------------------------------------------ #
This file contains the EPICS make rules and definitions for making and #
installing the driver support modules for the Micro-Research Finland # Series
200 event receiver
module. # #------------------------------------------------------------------------------ #
Modification History: # # 19 Dec 2005
Bjo Original Release # 21 Aug 2006
Saa Changes to build on RTEMS too. # 30 Aug
2006 Bjo Add host-side fractional
synthesizer
routines. # #------------------------------------------------------------------------------
#--------------------- # Set up the Environment # TOP
= ../.. SOURCE_DIR := $(patsubst %../.., %., $(TOP))
include $(TOP)/configure/CONFIG include
$(SOURCE_DIR)/MRF_CONFIG
INCLUDES += -I../os/$(OS_CLASS)
#USR_CFLAGS += -pedantic USR_CFLAGS +=
-DDEBUG_PRINT
ifeq ($(EPICS_HOST_ARCH),$(T_A))
USR_CFLAGS += -DHOST_BUILD endif
#--------------------- # Only build for "hardware"
IOC's # ifneq ($(findstring Host, $(VALID_BUILDS)),)
VALID_BUILDS = Host endif
#--------------------- # List all custom menu
headers # CUSTOM_MENUS += menuACSync.h CUSTOM_MENUS +=
menuEventClockSrc.h CUSTOM_MENUS += menuEventEnable.h CUSTOM_MENUS +=
menuLinkStatus.h CUSTOM_MENUS += menuPolarity.h CUSTOM_MENUS +=
menuSeqMode.h CUSTOM_MENUS += menuSeqRam.h CUSTOM_MENUS +=
menuTimeUnit.h
#--------------------- # Build the record support
modules # CUSTOM_RECORDS += egRecord CUSTOM_RECORDS +=
egeventRecord CUSTOM_RECORDS += erRecord CUSTOM_RECORDS +=
ereventRecord
#--------------------- # Install DBD files # DBD +=
mrfCommon.dbd
# wanglin 20100830 DBD += devMrfEgEvent.dbd
DBD += drvMrfEg.dbd DBD += devMrfEg.dbd DBD +=
mrfEg.dbd
DBD += drvMrfEr.dbd DBD += devMrfEr.dbd DBD +=
mrfEr.dbd
# wanglin 20100819 DBD += mrfbase.dbd mrfbase_DBD +=
base.dbd
#--------------------- # Install DBD Header
Files # DBDINC += $(CUSTOM_RECORDS) DBDINC +=
$(CUSTOM_MENUS)
#--------------------- # Build the MRF Common
Library # LIBRARY_IOC += mrfCommon
mrfCommon_OBJS += mrfFracSynth mrfCommon_OBJS +=
mrfVme64x mrfCommon_OBJS += $(CRCSR_PROBE_NAME)
OBJS_IOC += $(mrfCommon_OBJS)
#--------------------- # Build the Event Generator
Library # PROD_IOC_vxWorks +=
mrfEgLib LIBRARY_IOC += mrfEg
mrfEg_OBJS += drvMrfEg mrfEg_OBJS +=
devMrfEg #mrfEg_OBJS += devMrfEgEvent
mrfEg_OBJS += egRecord mrfEg_OBJS +=
egeventRecord
mrfEgLib_OBJS += $(mrfEg_OBJS) mrfEgLib_OBJS +=
$(mrfCommon_OBJS) mrfEgLib_SRCS +=
mrfEg_registerRecordDeviceDriver.cpp
mrfEgLib_LIBS += $(EPICS_BASE_IOC_LIBS)
OBJS_IOC += $(mrfEg_OBJS)
#--------------------- # Build the Event Receiver
mrfErLib LIBRARY_IOC += mrfEr
mrfEr_OBJS += drvMrfEr mrfEr_OBJS += mrfPmc mrfEr_OBJS
+= mrfPmcOSD mrfEr_OBJS += devMrfEr mrfEr_OBJS += erRecord mrfEr_OBJS
+= ereventRecord
mrfErLib_OBJS += $(mrfEr_OBJS) mrfErLib_OBJS +=
$(mrfCommon_OBJS) mrfErLib_SRCS +=
mrfEr_registerRecordDeviceDriver.cpp
mrfErLib_LIBS += $(EPICS_BASE_IOC_LIBS)
OBJS_IOC += $(mrfEr_OBJS)
#--------------------- # Build the host-side utilities for
creating and analyzing # the fractional synthesizer control
words. # PROD_HOST += FracSynthAnalyze PROD_HOST +=
FracSynthControlWord
FracSynthAnalyze_OBJS +=
FracSynthAnalyze FracSynthAnalyze_OBJS += mrfFracSynth
FracSynthControlWord_OBJS +=
FracSynthControlWord FracSynthControlWord_OBJS += mrfFracSynth
#--------------------- # Install include files # INC
+= mrfCommon.h INC += mrfVme64x.h INC += mrfFracSynth.h
INC += drvMrfEg.h INC += drvMrfEr.h INC +=
devMrfEr.h
INC += debugPrint.h
RULES
#--------------------- # Generic EPICS build
rules # include $(TOP)/configure/RULES
The start script st.cmd is :
## Example vxWorks startup file
cd "/home/wanglin/timingApp" ## You may have to change mrf
to something else ## everywhere it appears in this file
ld < bin/vxWorks-ppc604_long/mrfEgLib.munch ld <
bin/vxWorks-ppc604_long/mrfErLib.munch rebootHookAdd
components dbLoadDatabase("dbd/mrfEg.dbd") dbLoadDatabase("dbd/mrfEr.dbd") #dbLoadDatabase("dbd/mrfbase.dbd")
mrfEg_registerRecordDeviceDriver(pdbbase) mrfEr_registerRecordDeviceDriver(pdbbase)
## Load record
1
CardNo=3") dbLoadRecords("db/csnsEvr.db", "SUBSYS=timing, DEVICE=test, No=0,
PulseWidth=20 ") #dbLoadRecords("db/dbExample2.db","user=epics,no=1,scan=1
second")
EgConfigure(0, 3, 0x280000) ErConfigureVME(0, 5, 0x300000,
0x62, 4)
iocInit()
In additional :
[wanglin@timinglinux1 src]$ grep epicsExportAddress
egRecord.c epicsExportAddress (rset, egRSET); [wanglin@timinglinux1 src]$
grep epicsExportAddress egeventRecord.c epicsExportAddress (rset,
egeventRSET); [wanglin@timinglinux1 src]$ grep epicsExportAddress
devMrfEg.c epicsExportAddress (dset, devEg); epicsExportAddress (dset,
devEgEvent); [wanglin@timinglinux1 src]$ grep epicsExportAddress
drvMrfEg.c epicsExportAddress (drvet, drvMrf200Eg);
I have checked the database definition and record/device
support files,but cant't find any problems.Does anyone know what may result in
such errors?
Wang Lin
