Hi all,
All redirects don't work, neither "ld < library" nor "< script". The startup
script terminates after these redirects. I also found that a "cd" within the
startup script is reversed after the script ended.
I use
SHELL_COMPATIBLE TRUE
but SHELL_TASK_OPTIONS has the option VX_PRIVATE_ENV set. Maybe that is the
problem. I tried 6.2 and will try 6.7 soon.
Can anyone check these configs:
/* Shell default configuration */
#define SHELL_SECURE FALSE
#define SHELL_START_AT_BOOT TRUE
#define SHELL_COMPATIBLE TRUE
#define SHELL_DEFAULT_CONFIG \
"LINE_EDIT_MODE=,LINE_LENGTH=256,STRING_FREE=manual,INTERPRETER=,VXE_PATH=.;/romfs"
#define SHELL_FIRST_CONFIG NULL
#define SHELL_REMOTE_CONFIG NULL
#define SHELL_TASK_NAME_BASE "tShell"
#define SHELL_TASK_PRIORITY 1
#define SHELL_TASK_OPTIONS (VX_FP_TASK | VX_UNBREAKABLE | COPROCS_ALL |
VX_PRIVATE_ENV)
I am using INCLUDE_SHELL but none of
INCLUDE_SHELL_VI_MODE
INCLUDE_SHELL_EMACS_MODE
INCLUDE_SHELL_INTERP_C
INCLUDE_SHELL_INTERP_CMD
Should I include any of these?
Dirk
Andrew Johnson wrote:
Hi Dirk,
On Wednesday 19 August 2009 05:42:19 Dirk Zimoch wrote:
Generally, vxWorks 6 has some new features (e.g. real time
processes) which
are not used by EPICS. vxWorks 6 still supports running
applications, e.g.
EPICS, in "kernel space" (which is all you had in vxWorks 5).
However, the
vxWorks shell has changed a bit and not everything that worked in
vxWorks 5
startup scripts might work in vxWork 6 startup scripts (I had
difficulties
sourcing other scripts). I think I can tell more once I have the
MVME4100
running.
I wonder if your sourcing scripts problem is the the same issue we
found when we upgraded to vxWorks 5.5.2 - if you use the construct
ld < ioc.munch
in your startup script then all subsequent shell redirections to
source other scripts get ignored. The solution is to replace the
above line with this
ld 0, 0, "ioc.munch"
which permits later shell source commands to operate normally. I
think it's highly likely that Wind River broke both versions of the
target shell at the same time...
I am also not having problems with this.
However, in the beginning I bumped into this as well.
We are using vxWorks 6.6 on some projects here at SLAC:
Using the vxWorks project facility please do the following:
vxprj parameter set SHELL_COMPATIBLE TRUE
vxprj parameter set SHELL_TASK_OPTIONS "(VX_FP_TASK | VX_UNBREAKABLE |
COPROCS_ALL)"
I had to make similar changes when I was at the SNS as well.
Sorry, I forgot to add you must rebuild your kernel after these changes:
vxprj build
Cheers,
Ernest
Ernest
- Andrew
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- RE: VME SBC suggestion? Williams Jr., Ernest L.
- VME SBC suggestion? Dimitrios Tsifakis
- Re: VME SBC suggestion? Dimitrios Tsifakis
- Re: VME SBC suggestion? Dirk Zimoch
- Re: VME SBC suggestion? Andrew Johnson
- Re: VME SBC suggestion? Ernest L. Williams Jr.
Re: anyone seen this error Dirk Zimoch
Re: anyone seen this error Pierrick Hanlet
<2009>
<2009>
