1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: anyone seen this error
To: Dirk Zimoch <[email protected]>
Date: Thu, 20 Aug 2009 06:57:30 -0500
Hi Dirk,
Thanks for responding.
No, I'm actually running this soft IOC as a simulation for development.  It is connected to
an EDM panel from which I'm inputting values to the IOC.  However, since I don't have
this environment variable set, I'll do so now.
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039         office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
----- Original Message -----
Date: Thursday, August 20, 2009 6:26 am
To: Pierrick Hanlet <[email protected]>
> Hi Pierrick,
> If your OUT is a CA link (to another IOC) make sure to set
> EPICS_CA_MAX_ARRAY_BYTES large enough (default is 16k) on both IOCs.
> Dirk
> Pierrick Hanlet wrote:
> > Hi,
> > I'm using genSubRecord with both input "A" and output "OUTA" fields.
> > I have the following error:
> > Link U - Array too large! 1993313664 Bytes
> > which shows up after
> > iocInit
> > Starting iocInit
> > ## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
> > ## EPICS Base built May 29 2009
> > If I comment out the "field(OUTA" line, I don't get this error.  Has
> anyone ever seen this?
> > Thanks,
> > Pierrick
> > Pierrick Hanlet
> > Batavia, IL 60510
> > [email protected]
> Dr. Dirk Zimoch
> Paul Scherrer Institut, WBGB/006
> 5232 Villigen PSI, Switzerland
> Phone +41 56 310 5182
Re: anyone seen this error Andrew Johnson
anyone seen this error Pierrick Hanlet
Re: anyone seen this error Dirk Zimoch
Prev: Re: VME SBC suggestion? Dirk Zimoch
Next: RE: VME SBC suggestion? Williams Jr., Ernest L.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: anyone seen this error Dirk Zimoch
Next: Re: anyone seen this error Andrew Johnson
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
