Hi Pierrick,
If your OUT is a CA link (to another IOC) make sure to set
EPICS_CA_MAX_ARRAY_BYTES large enough (default is 16k) on both IOCs.
Dirk
Pierrick Hanlet wrote:
I'm using genSubRecord with both input "A" and output "OUTA" fields.
I have the following error:
Link U - Array too large! 1993313664 Bytes
which shows up after
iocInit
Starting iocInit
## EPICS R3.14.10 $R3-14-10$ $2008/10/27 19:39:04$
## EPICS Base built May 29 2009
If I comment out the "field(OUTA" line, I don't get this error. Has anyone ever seen this?
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 122
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- Re: anyone seen this error Pierrick Hanlet
- anyone seen this error Pierrick Hanlet
Re: VME SBC suggestion? Dirk Zimoch
<2009>
<2009>
