Hi Dirk,
Yes, that is the problem don't use "VX_PRIVATE_ENV"
Go ahead and set the options I gave and you should be fine.
(i.e. SHELL_TASK_OPTIONS)
Cheers,
Ernest
-----Original Message-----
Sent: Thu 8/20/2009 4:35 AM
To: Williams Jr., Ernest L.
Cc: Andrew Johnson; Dimitrios Tsifakis; [email protected]
Subject: Re: VME SBC suggestion?
Hi all,
All redirects don't work, neither "ld < library" nor "< script". The startup
script terminates after these redirects. I also found that a "cd" within the
startup script is reversed after the script ended.
I use
SHELL_COMPATIBLE TRUE
but SHELL_TASK_OPTIONS has the option VX_PRIVATE_ENV set. Maybe that is the
problem. I tried 6.2 and will try 6.7 soon.
Can anyone check these configs:
/* Shell default configuration */
#define SHELL_SECURE FALSE
#define SHELL_START_AT_BOOT TRUE
#define SHELL_COMPATIBLE TRUE
#define SHELL_DEFAULT_CONFIG \
"LINE_EDIT_MODE=,LINE_LENGTH=256,STRING_FREE=manual,INTERPRETER=,VXE_PATH=.;/romfs"
#define SHELL_FIRST_CONFIG NULL
#define SHELL_REMOTE_CONFIG NULL
#define SHELL_TASK_NAME_BASE "tShell"
#define SHELL_TASK_PRIORITY 1
#define SHELL_TASK_OPTIONS (VX_FP_TASK | VX_UNBREAKABLE | COPROCS_ALL |
VX_PRIVATE_ENV)
I am using INCLUDE_SHELL but none of
INCLUDE_SHELL_VI_MODE
INCLUDE_SHELL_EMACS_MODE
INCLUDE_SHELL_INTERP_C
INCLUDE_SHELL_INTERP_CMD
Should I include any of these?
Dirk
>> Andrew Johnson wrote:
>>> Hi Dirk,
>>> On Wednesday 19 August 2009 05:42:19 Dirk Zimoch wrote:
>>>> Generally, vxWorks 6 has some new features (e.g. real time
>>>> processes) which
>>>> are not used by EPICS. vxWorks 6 still supports running
>>>> applications, e.g.
>>>> EPICS, in "kernel space" (which is all you had in vxWorks 5).
>>>> However, the
>>>> vxWorks shell has changed a bit and not everything that worked in
>>>> vxWorks 5
>>>> startup scripts might work in vxWork 6 startup scripts (I had
>>>> difficulties
>>>> sourcing other scripts). I think I can tell more once I have the
>>>> MVME4100
>>>> running.
>>> I wonder if your sourcing scripts problem is the the same issue we
>>> found when we upgraded to vxWorks 5.5.2 - if you use the construct
>>> ld < ioc.munch
>>> in your startup script then all subsequent shell redirections to
>>> source other scripts get ignored. The solution is to replace the
>>> above line with this
>>> ld 0, 0, "ioc.munch"
>>> which permits later shell source commands to operate normally. I
>>> think it's highly likely that Wind River broke both versions of the
>>> target shell at the same time...
>> I am also not having problems with this.
>> However, in the beginning I bumped into this as well.
>> We are using vxWorks 6.6 on some projects here at SLAC:
>> Using the vxWorks project facility please do the following:
>> vxprj parameter set SHELL_COMPATIBLE TRUE
>> vxprj parameter set SHELL_TASK_OPTIONS "(VX_FP_TASK | VX_UNBREAKABLE |
>> COPROCS_ALL)"
>> I had to make similar changes when I was at the SNS as well.
> Sorry, I forgot to add you must rebuild your kernel after these changes:
> vxprj build
> Cheers,
> Ernest
>> Thanks,
>> Ernest
>>> - Andrew
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- VME SBC suggestion? Dimitrios Tsifakis
- Re: VME SBC suggestion? Dimitrios Tsifakis
- Re: VME SBC suggestion? Dirk Zimoch
- Re: VME SBC suggestion? Andrew Johnson
- Re: VME SBC suggestion? Ernest L. Williams Jr.
Re: anyone seen this error Pierrick Hanlet
Re: anyone seen this error Andrew Johnson
<2009>
UMAC - PowerPMAC thermal issue Joe Sullivan
<2009>
