1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Detecting data lost from a subscriber
To: Ralph Lange <[email protected]>
Cc: [email protected]
Date: Wed, 08 Jul 2009 15:58:13 +0200
Le mercredi 08 juillet 2009 à 11:08 +0200, Ralph Lange a écrit :
> Hello Bruno,
> you should take Bob's statement as a "no".
Thanks, that is what I understood.
> Channel Access itself silently overwrites entries in the send queue, and
> does not provide the client with information that or how many updates
> were lost.
> If you want that functionality, you have to add the needed information
> to the data. E.g. use a sub record and add C code that acts as a simple
> counter and mangles a sequence number into your data. Plus client code
> to separate things again.
I see.
> Careful: Array data is not put into the server side queue (only
> references to the array), so using an array to add the sequence number
> would at the same time enable you to detect missing updates and create a
> lot of missing updates. (Probably not what you want.)
I don't understand this point. In what would it make things worse, could
you please explain me.
> Another option is to reverse client and server sides: If your data
> source acts as a CA client, it can use CA put-complete calls that would
> implement a handshake. That technique doesn't allow multiple
> subscriptions to the same value, of course.
I don't need to go that far but thanks for the idea.
Bruno.
Re: Detecting data lost from a subscriber Ralph Lange
Detecting data lost from a subscriber Bruno Coudoin
RE: Detecting data lost from a subscriber Dalesio, Leo
Prev: Re: EDM X-Y Graph zoom shrinks with its zoom? Carl Schumann
Next: Re: EDM X-Y Graph zoom shrinks with its zoom? Dennis Nicklaus
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Detecting data lost from a subscriber Ralph Lange
Next: Re: Detecting data lost from a subscriber Ralph Lange
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
