1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EDM X-Y Graph zoom shrinks with its zoom?
To: John Sinclair <[email protected]>
Cc: [email protected]
Date: Wed, 08 Jul 2009 07:25:28 -0500
It might be best to ask my users what they think would make sense, but I will answer for them anyway. If I understand you, your point is that the new labels themselves can take up more space 10 vs. 0.000053 and therefore leave less room for the graph proper. That is true. However, in the example I gave there is loss not just due to the increased label width, but also because the border has increased. If the original border was retained there would be more space for graph proper.
John Sinclair wrote:
Are you saying that you want edm to anticipate the space it needs to display all formats in advance or are you saying that you want 0.000053 to fit in the same space taken by 10? Of course, if you give the graph more real estate, the difference will seem much less pronounced.
Carl Schumann wrote:
Our EDM user's have noticed that the X-Y Graph widget's zoom feature does the zoom but in a smaller area than the original graph. So this means the zoom does not zoom so well as it could if it made use of all the space originally and still available. I have attached two images to illustrate. They are labeled before and after. Each image has two widgets only the top on gets zoomed. The bottom is for scale. Anybody see things issue also? Any fixes?
Carl Schumann
EDM X-Y Graph zoom shrinks with its zoom? Carl Schumann
Re: EDM X-Y Graph zoom shrinks with its zoom? John Sinclair
Prev: Re: Detecting data lost from a subscriber Ralph Lange
Next: Re: Detecting data lost from a subscriber Bruno Coudoin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EDM X-Y Graph zoom shrinks with its zoom? John Sinclair
Next: Re: EDM X-Y Graph zoom shrinks with its zoom? Dennis Nicklaus
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
