1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Detecting data lost from a subscriber
To: Bruno Coudoin <[email protected]>
Cc: [email protected]
Date: Wed, 08 Jul 2009 11:08:43 +0200
Hello Bruno,
you should take Bob's statement as a "no".
Channel Access itself silently overwrites entries in the send queue, and does not provide the client with information that or how many updates were lost.
If you want that functionality, you have to add the needed information to the data. E.g. use a sub record and add C code that acts as a simple counter and mangles a sequence number into your data. Plus client code to separate things again. Careful: Array data is not put into the server side queue (only references to the array), so using an array to add the sequence number would at the same time enable you to detect missing updates and create a lot of missing updates. (Probably not what you want.)
Another option is to reverse client and server sides: If your data source acts as a CA client, it can use CA put-complete calls that would implement a handshake. That technique doesn't allow multiple subscriptions to the same value, of course.
Good luck!
Ralph
On 07.07.2009 19:22 Dalesio, Leo wrote:
The last value in the queue is overwritten with the latest value.
Bob
-----Original Message-----
Sent: Tue 7/7/2009 1:00 PM
To: [email protected]
Subject: Detecting data lost from a subscriber
As I understand it, the CAS server just discards data if the queue is
full for a subscriber.
In this case, is there a way for the subscriber to know that a sample
has been lost ?
Bruno.
Re: Detecting data lost from a subscriber Bruno Coudoin
RE: Detecting data lost from a subscriber Dalesio, Leo
Prev: Re: File Chooser John Sinclair
Next: Re: EDM X-Y Graph zoom shrinks with its zoom? Carl Schumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Detecting data lost from a subscriber Dalesio, Leo
Next: Re: Detecting data lost from a subscriber Bruno Coudoin
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
