1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: File Chooser
To: "Szalata, Zenon M." <[email protected]>
Cc: [email protected]
Date: Tue, 07 Jul 2009 22:01:11 -0400
Zen,
You can get a file chooser with the text control widget. The incantation is in the online doc as
  Editable + keypad + file + pv type = string: edit with file select box
With these options you also set "default dir" and "pattern" to something like "./" and "*.txt" respectively.
You also choose the form of the returned string which may be "full path", "name & ext", or "name only".
Szalata, Zenon M. wrote:
 I have written a soft IOC which reads data from a disk file and places values read into EPICS records.  A few EDM screens are used to display the data...
All of this works fine.
There a number of disk files to choose from.
I have implemented a simple way to specify the file name using a waveform record and a text control.  This scheme is very difficult to use.
I think that EDM does not provide a file name chooser dialog.  Is that true?
If so, has anyone implemented some EDM widget which could be used to choose a file name from existing files on a disk drive?
Thanks in advance,
Zen
choosing snmp version Pierrick Hanlet
File Chooser Szalata, Zenon M.
Prev: Re: EDM X-Y Graph zoom shrinks with its zoom? John Sinclair
Next: Re: Detecting data lost from a subscriber Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: File Chooser Munro Jr, John K.
Next: Re: choosing snmp version Euan Troup
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
