1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICs base MingW32 compilation failed !
To: [email protected]
Cc: URIOT Didier <[email protected]>
Date: Thu, 8 Jan 2009 15:30:09 -0600
On Thursday 08 January 2009 07:56:55 Jens Eden wrote:
> Consider going back to gcc 3.4.2 (MinGW 4.1.1), which hasn't that problem.
> You can get older releases from the mirror sites as described here:
> http://www.mingw.org/old/download.shtml
Bingo!  Thanks, that works for me too.
I also seem to be able to build with Cygwin too, contrary to my previous
message..
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
EPICs base MingW32 compilation failed ! URIOT Didier
Re: EPICs base MingW32 compilation failed ! Jens Eden
Prev: Re: Scilab and epics Till Straumann
Next: Comparing catime performance Matt Rippa
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICs base MingW32 compilation failed ! Jens Eden
Next: Gateway fails with "epicsMutex pthread_mutex_lock failed: error Invalid argument" Mark Bennett
ANJ, 31 Jan 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
