I've setup an mvme2700 with RTEMS and an exampleApp (R3.14.10). I was wondering how my catime results compare with other sites using other boards or OS. Is there an expectation for a 10/100 port? I've already seen the notes on the mvme-5500 and it looks like my setup isn't quite as good: http://www.aps.anl.gov/epics/tech-talk/2005/msg00265.php Perhaps my subnet is busy.
-- > catime mrippa:aiExample Testing with 10000 channels named mrippa:aiExample channel connect test Elapsed Per Item = 0.00042084 sec, 2376.2 Items per sec, 1.3 Mbps Search tries per chan - mean=1.032500 std dev=0.203577 min=1.000000 max=3.000000 channel name=mrippa:aiExample, native type=6, native count=1 pend event test Elapsed Per Item = 0.00000342 sec, 292758.6 Items per sec float test async put test Elapsed Per Item = 0.00000897 sec, 111438.1 Items per sec, 15.2 Mbps async get test Elapsed Per Item = 0.00019678 sec, 5081.7 Items per sec, 1.3 Mbps synch get test Elapsed Per Item = 0.00022803 sec, 4385.4 Items per sec, 1.2 Mbps double test async put test Elapsed Per Item = 0.00000898 sec, 111321.7 Items per sec, 15.1 Mbps async get test Elapsed Per Item = 0.00019742 sec, 5065.3 Items per sec, 1.3 Mbps synch get test Elapsed Per Item = 0.00023804 sec, 4201.0 Items per sec, 1.1 Mbps string test async put test Elapsed Per Item = 0.00001010 sec, 99040.4 Items per sec, 16.6 Mbps async get test Elapsed Per Item = 0.00019695 sec, 5077.3 Items per sec, 1.5 Mbps synch get test Elapsed Per Item = 0.00022858 sec, 4374.8 Items per sec, 1.3 Mbps integer test async put test Elapsed Per Item = 0.00000906 sec, 110324.7 Items per sec, 15.0 Mbps async get test Elapsed Per Item = 0.00022911 sec, 4364.7 Items per sec, 1.2 Mbps synch get test Elapsed Per Item = 0.00022638 sec, 4417.3 Items per sec, 1.2 Mbps round trip jitter test Round trip get delays - mean=0.000228 sec, std dev=0.000008 sec, min=0.000221 sec max=0.000469 sec free test Elapsed Per Item = 0.00000056 sec, 1794331.9 Items per sec, 0.0 Mbps
| ANJ, 02 Sep 2010 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
