URIOT Didier schrieb:
> Hello,
> I tried to compile EPICS base 3.14.10 on a windows computer with gcc 3.4.5
> I followed the install instruction, and compilation started correctly
> but after a fews secondes I had the following message.
Consider going back to gcc 3.4.2 (MinGW 4.1.1), which hasn't that problem.
You can get older releases from the mirror sites as described here:
http://www.mingw.org/old/download.shtml
Jens
- Re: EPICs base MingW32 compilation failed ! Andrew Johnson
- EPICs base MingW32 compilation failed ! URIOT Didier
Gateway fails with "epicsMutex pthread_mutex_lock failed: error Invalid argument" Mark Bennett
Scilab and epics Emmanuel Mayssat
<2009>
<2009>
