1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Asyn/VXI-11 problems
To: [email protected]
Cc: [email protected]
Date: Tue, 09 Oct 2007 14:29:37 +0200
Hi Ben,
Just coming back from vacation I found this:
Benjamin Franksen wrote:
Ok, I've found one bug in stream version 2-2 that leads to a crash. A format of "%*[whatever>]"
gets converted internally to "%0[whatever>]%n" and then only /one/ pointer arg is provided to sscanf, instead of two. The method where sscanf crashes is in StreamFormatConverter.cc:
This bug had been reported to me by Emma Shepherd on August 27. A patch to fix this bug is available on the StreamDevice web page since the same day.
If you find bugs, I can only fix them if you report them!
Watch the web page for patches.
Dirk
int StdCharsetConverter:: scanString(const StreamFormat& fmt, const char* input, char* value, size_t maxlen) { int length = -1; if (fmt.flags & skip_flag) { if (sscanf (input, fmt.info, &length) < 0) return -1; } ....
Since skip_flag is set only for %* formats, it is wrong to replace it with %0. Thus the parse method must be changed, like this (see comments):
parse(const StreamFormat& fmt, StreamBuffer& info,
const char*& source, bool scanFormat)
if (!scanFormat)
error("Format conversion %%[ is only allowed in input formats\n");
return false;
if (fmt.flags & (left_flag|sign_flag|space_flag|zero_flag|alt_flag))
error("Use of modifiers '-', '+', ' ', '0', '#'"
"not allowed with %%%c conversion\n",
fmt.conv);
return false;
if (scanFormat && fmt.prec >= 0)
error("Use of precision field '.%d' not allowed with %%%c input conversion\n",
fmt.prec, fmt.conv);
return false;
// fix: bfr 20/09/07
if (fmt.flags & skip_flag ) {
info.printf("%%*[");
else {
info.printf("%%%d[", fmt.width);
// end fix
while (*source && *source != ']')
if (*source == esc) source++;
info.append(*source++);
if (!*source) {
error("Missing ']' after %%[ format conversion\n");
return false;
source++; // consume ']'
info.append("]%n");
return string_format;
However, the IOC crashes anyway, because this is just one of many bugs. I'll send more debugger output soon.
Cheers
Ben
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
StreamDevice (was: Re: Asyn/VXI-11 problems) Benjamin Franksen
Re: Asyn/VXI-11 problems J. Lewis Muir
Asyn/VXI-11 problems Benjamin Franksen
Re: Asyn/VXI-11 problems Eric Norum
Re: Asyn/VXI-11 problems Benjamin Franksen
Prev: Re: Use of waveform records Touchard Dominique
Next: StreamDevice (was: Re: Asyn/VXI-11 problems) Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Asyn/VXI-11 problems Benjamin Franksen
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
