1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Asyn/VXI-11 problems
To: Jeff Hill <[email protected]>
Cc: [email protected]
Date: Tue, 18 Sep 2007 10:03:44 -0500
On Sep 18, 2007, at 9:59 AM, Jeff Hill wrote:
Hi Ben,
You might try commenting out iocInit in the startup script, and then after
the IOC boots up type "sp iocInit". When it fails type "tt <task id>" to get
the stack trace. If that doesn't help you might also build for debugging and
attach the Tornado debugger to the IOC.
This is running on linux so Benjamin needs only to run the IOC under gdb.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: Asyn/VXI-11 problems Benjamin Franksen
RE: Asyn/VXI-11 problems Jeff Hill
Prev: RE: Asyn/VXI-11 problems Jeff Hill
Next: Re: Beginer problem Luedeke Andreas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Asyn/VXI-11 problems Benjamin Franksen
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
