On Tuesday 18 September 2007 17:03, Eric Norum wrote:
> On Sep 18, 2007, at 9:59 AM, Jeff Hill wrote:
> > Hi Ben,
> > You might try commenting out iocInit in the startup script, and
> > then after
> > the IOC boots up type "sp iocInit". When it fails type "tt <task
> > id>" to get
> > the stack trace. If that doesn't help you might also build for
> > debugging and
> > attach the Tornado debugger to the IOC.
> This is running on linux so Benjamin needs only to run the IOC under
> gdb.
I have run it under ddd and valgrind and attached the outputs. I used
asyn4-8 and stream2-2. The problem /appears/ to be in stream support
(contrary to what I thought at first). OTOH, the many many timeouts are
completely inexplicable to me and suggest that there is something wrong
with asyn/vxi-11, too. Anyway, I am completely lost; I have great
difficulty understabnding the relevant stream (C++) code.
Cheers
Ben
"Programming = Mathematics + Murphy's Law" (E.W.Dijkstra)
GNU DDD 3.3.11 (i686-pc-linux-gnu), by Dorothea Ltkehaus and Andreas Zeller.
Copyright 1995-1999 Technische Universitt Braunschweig, Germany.
Copyright 1999-2001 Universitt Passau, Germany.
Copyright 2001 Universitt des Saarlandes, Germany.
Copyright 2001-2004 Free Software Foundation, Inc.
Using host libthread_db library "/lib/tls/libthread_db.so.1".
(gdb) run st.cmd
Failed to read a valid object file image from memory.
[Thread debugging using libthread_db enabled]
[New Thread -1211385792 (LWP 32766)]
#!../../bin/linux-x86/SIOC6CP
# Change to top directory
cd ../..
########################################################### Set up Environment
epicsEnvSet IOC SIOC6CP
epicsEnvSet LOG_DIR log
epicsEnvSet EPICS_CA_PUT_LOG_INET 192.168.48.97
epicsEnvSet STREAM_PROTOCOL_PATH db
############################################## Register all support components
dbLoadDatabase dbd/SIOC6CP.dbd 0 0
SIOC6CP_registerRecordDeviceDriver pdbbase
############################################################ Configure drivers
# Reboot E5810
# E5810Reboot box6.acc.bessy.de E5810
# Configure asyn vxi-11 driver for GPIB box
vxi11Configure L3 tcl-101-134-Host.tcl.bessy.de 1 10 gpib0
[New Thread -1211389008 (LWP 326)]
[New Thread -1211651152 (LWP 327)]
[New Thread -1211913296 (LWP 328)]
####################################################### Autosave configuration
set_requestfile_path db
set_savefile_path log/autoSaveRestore
save_restoreSet_DatedBackupFiles 1
save_restoreSet_UseStatusPVs 0
######################################################## Load record instances
dbLoadRecords db/NRVD.db
######################################################## Restore record values
#set_pass0_restoreFile <irgendwas>.sav
########################################################### Configure IOC Core
# IOC Log Server Connection 0=enabled 1=disabled
setIocLogDisable 0
# Configure Access Security
asSetFilename db/no_security.acf
#################################################################### Start IOC
iocInit
[New Thread -1213203536 (LWP 329)]
Starting iocInit
### EPICS IOC CORE built on Aug 9 2007
### EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
[New Thread -1213334608 (LWP 330)]
[New Thread -1213596752 (LWP 331)]
[New Thread -1214121040 (LWP 332)]
[New Thread -1214645328 (LWP 333)]
[New Thread -1215169616 (LWP 334)]
[New Thread -1215431760 (LWP 335)]
initHooks: set_pass[0,1]_restoreFile() were never called.
initHooks: Specifying 'auto_settings.sav' and 'auto_positions.sav'
initHooks: for backward compatibility with old autosave/restore.
save_restore: Can't figure out which seq file is most recent,
save_restore: so I'm just going to start with 'log/autoSaveRestore/auto_positions.sav0'.
save_restore: Can't find a file to restore from...save_restore: ...last tried 'log/autoSaveRestore/auto_positions.sav2'. I give up.
save_restore: so I'm just going to start with 'log/autoSaveRestore/auto_settings.sav0'.
save_restore: Can't find a file to restore from...save_restore: ...last tried 'log/autoSaveRestore/auto_settings.sav2'. I give up.
[New Thread -1215956048 (LWP 336)]
2007/09/19 15:27:31.601 gpib0,20 vxiCreateDeviceLink RPC error : RPC: Timed out
2007/09/19 15:27:31.601 L3 vxiCreateDevLink failed for addr 20
2007/09/19 15:27:31.601 asynManager::asynConnectCallback, port L3 error calling asynCommon->connect
2007/09/19 15:27:35.601 gpib0,20 vxiCreateDeviceLink RPC error : RPC: Timed out
2007/09/19 15:27:35.601 L3 vxiCreateDevLink failed for addr 20
2007/09/19 15:27:35.601 NRVD:setPow(1): pasynCommon->connect() failed:
2007/09/19 15:27:35.601 NRVD:setPow(1): Can't start init run
2007/09/19 15:27:35.601 2007/09/19 15:27:35.601 asynManager::asynConnectCallback, port L3 error calling asynCommon->connect
NRVD:setPow(1): Record initialization failed
Bad init_rec return value PV: NRVD:setPow(1) ao: init_record
2007/09/19 15:27:39.601 gpib0,20 vxiCreateDeviceLink RPC error : RPC: Timed out
2007/09/19 15:27:39.601 L3 vxiCreateDevLink failed for addr 20
2007/09/19 15:27:39.601 asynManager::asynConnectCallback, port L3 error calling asynCommon->connect
2007/09/19 15:27:43.601 gpib0,20 vxiCreateDeviceLink RPC error : RPC: Timed out
2007/09/19 15:27:43.601 L3 vxiCreateDevLink failed for addr 20
2007/09/19 15:27:43.601 asynManager::asynConnectCallback, port L3 error calling asynCommon->connect
2007/09/19 15:27:47.600 gpib0,20 vxiCreateDeviceLink RPC error : RPC: Timed out
2007/09/19 15:27:47.601 L3 vxiCreateDevLink failed for addr 20
2007/09/19 15:27:47.601 NRVD:setPow(2): pasynCommon->connect() failed:
2007/09/19 15:27:47.601 gpib0,20 vxiCreateDeviceLink RPC error : RPC: Timed out
2007/09/19 15:27:47.601 NRVD:setPow(2): Can't start init run
2007/09/19 15:27:47.601 NRVD:setPow(2): Record initialization failed
2007/09/19 15:27:47.601 asynManager::asynConnectCallback, port L3 error calling asynCommon->connect
Bad init_rec return value PV: NRVD:setPow(2) ao: init_record
2007/09/19 15:27:51.600 gpib0,20 vxiCreateDeviceLink RPC error : RPC: Timed out
2007/09/19 15:27:51.600 L3 vxiCreateDevLink failed for addr 20
2007/09/19 15:27:51.600 NRVD:setRef(1): pasynCommon->connect() failed:
2007/09/19 15:27:51.600 NRVD:setRef(1): Can't start init run
2007/09/19 15:27:51.600 NRVD:setRef(1): Record initialization failed
Bad init_rec return value PV: NRVD:setRef(1) ao: init_record
2007/09/19 15:27:55.600 gpib0,20 vxiCreateDeviceLink RPC error : RPC: Timed out
2007/09/19 15:27:55.600 L3 vxiCreateDevLink failed for addr 20
2007/09/19 15:27:55.600 asynManager::asynConnectCallback, port L3 error calling asynCommon->connect
2007/09/19 15:27:59.604 gpib0,20 vxiCreateDeviceLink RPC error : RPC: Timed out
2007/09/19 15:27:59.604 L3 vxiCreateDevLink failed for addr 20
2007/09/19 15:27:59.604 NRVD:setRef(2): pasynCommon->connect() failed:
2007/09/19 15:27:59.604 2007/09/19 15:27:59.604 gpib0,20 vxiCreateDeviceLink RPC error : RPC: Timed out
NRVD:setRef(2): Can't start init run
2007/09/19 15:27:59.604 2007/09/19 15:27:59.604 asynManager::asynConnectCallback, port L3 error calling asynCommon->connect
NRVD:setRef(2): Record initialization failed
Bad init_rec return value PV: NRVD:setRef(2) ao: init_record
2007/09/19 15:28:03.608 gpib0,20 vxiCreateDeviceLink RPC error : RPC: Timed out
2007/09/19 15:28:03.608 L3 vxiCreateDevLink failed for addr 20
2007/09/19 15:28:03.608 asynManager::asynConnectCallback, port L3 error calling asynCommon->connect
2007/09/19 15:28:03.608 NRVD:selDispEn: pasynCommon->connect() failed:
2007/09/19 15:28:03.608 NRVD:selDispEn: Can't start init run
2007/09/19 15:28:03.608 NRVD:selDispEn: Record initialization failed
2007/09/19 15:28:07.608 gpib0,20 vxiCreateDeviceLink RPC error : RPC: Timed out
2007/09/19 15:28:07.608 L3 vxiCreateDevLink failed for addr 20
2007/09/19 15:28:07.608 asynManager::asynConnectCallback, port L3 error calling asynCommon->connect
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1211651152 (LWP 327)]
0xb7d1418b in _IO_vfscanf () from /lib/tls/libc.so.6
(gdb) backtrace
#0 0xb7d1418b in _IO_vfscanf () from /lib/tls/libc.so.6
#1 0xb7d1f72d in vsscanf () from /lib/tls/libc.so.6
#2 0xb7d1a80d in sscanf () from /lib/tls/libc.so.6
#3 0x08061664 in StdCharsetConverter::scanString (this=0x8195d50, fmt=@0x0, input=0xb7b2e2c4 "POW W\n", value=0xb7c7a35c "POW", maxlen=3) at ../StreamFormatConverter.cc:409
#4 0x08067218 in StreamCore::matchInput (this=0xb7b2deb8) at StreamFormatConverter.h:68
#5 0x08065c6f in StreamCore::readCallback (this=0xb7b2deb8, status=StreamIoEnd, input=0xb7b2e50c, size=7) at ../StreamCore.cc:1009
#6 0x0806a79f in AsynDriverInterface::readHandler (this=0xb7b2e488) at StreamBusInterface.h:111
#7 0x0806bc6c in handleRequest (pasynUser=0xb7c7a34c) at ../AsynDriverInterface.cc:1278
#8 0x0807c7db in portThread (pport=0x81a3818) at ../../asyn/asynDriver/asynManager.c:777
#9 0x0814541c in start_routine (arg=0x81f2ca8) at ../../../src/libCom/osi/os/posix/osdThread.c:320
#10 0xb7f4db63 in start_thread () from /lib/tls/libpthread.so.0
#11 0xb7d9418a in clone () from /lib/tls/libc.so.6
(gdb)
==32192== Memcheck, a memory error detector for x86-linux.
==32192== Copyright (C) 2002-2005, and GNU GPL'd, by Julian Seward et al.
==32192== Using valgrind-2.4.0, a program supervision framework for x86-linux.
==32192== Copyright (C) 2000-2005, and GNU GPL'd, by Julian Seward et al.
==32192== Valgrind library directory: /usr/lib/valgrind
==32192== Command line
==32192== ../../bin/linux-x86/SIOC6CP
==32192== st.cmd
==32192== Startup, with flags:
==32192== --suppressions=/usr/lib/valgrind/debian-libc6-dbg.supp
==32192== -v
==32192== --
==32192== Contents of /proc/version:
==32192== Linux version 2.6.18.2 (root@aragon) (gcc version 3.3.5 (Debian 1:3.3.5-13)) #1 SMP PREEMPT Tue Nov 14 17:22:28 CET 2006
==32192== Reading syms from /srv/projects/ctl/franksen/epics/ioc/MLS-Controls/ralf/bin/linux-x86/SIOC6CP (0x8048000)
==32192== Reading syms from /lib/ld-2.3.2.so (0x1B8E4000)
==32192== object doesn't have a symbol table
==32192== Reading debug info from /lib/ld-2.3.2.so...
==32192== ... CRC mismatch (computed 21E2679B wanted A7C43B47)
==32192== object doesn't have any debug info
==32192== Reading syms from /usr/lib/valgrind/stage2 (0xB0000000)
==32192== Reading syms from /lib/ld-2.3.2.so (0xB1000000)
==32192== Reading syms from /usr/lib/valgrind/vgskin_memcheck.so (0xB7B7D000)
==32192== Reading syms from /lib/tls/libc-2.3.2.so (0xB7DE1000)
==32192== Reading debug info from /lib/tls/libc-2.3.2.so...
==32192== ... CRC mismatch (computed CFB0E393 wanted 21B6B5AC)
==32192== Reading syms from /lib/tls/libdl-2.3.2.so (0xB7F16000)
==32192== Reading debug info from /lib/tls/libdl-2.3.2.so...
==32192== ... CRC mismatch (computed 7A0DEF56 wanted EB21573A)
==32192== Reading suppressions file: /usr/lib/valgrind/debian-libc6-dbg.supp
==32192== Reading suppressions file: /usr/lib/valgrind/default.supp
==32192==
==32192== Reading syms from /usr/lib/valgrind/vg_inject.so (0x1B900000)
==32192== Reading syms from /usr/lib/valgrind/vgpreload_memcheck.so (0x1B903000)
==32192== Reading syms from /lib/tls/libpthread-0.60.so (0x1B929000)
==32192== Reading debug info from /lib/tls/libpthread-0.60.so...
==32192== ... CRC mismatch (computed 8AAA646A wanted A29D44A6)
==32192== Reading syms from /lib/libreadline.so.5.0 (0x1B93B000)
==32192== Reading syms from /lib/libncurses.so.5.4 (0x1B969000)
==32192== Reading syms from /lib/tls/librt-2.3.2.so (0x1B9A9000)
==32192== Reading debug info from /lib/tls/librt-2.3.2.so...
==32192== ... CRC mismatch (computed AB01EF7E wanted 3FBB05E7)
==32192== Reading syms from /usr/lib/libstdc++.so.5.0.7 (0x1B9B0000)
==32192== Reading syms from /lib/tls/libm-2.3.2.so (0x1BA6B000)
==32192== Reading debug info from /lib/tls/libm-2.3.2.so...
==32192== ... CRC mismatch (computed 97D2F5F5 wanted 22B6F3CD)
==32192== Reading syms from /lib/libgcc_s.so.1 (0x1BA8E000)
==32192== Reading syms from /lib/tls/libc-2.3.2.so (0x1BA9A000)
==32192== Reading syms from /lib/tls/libdl-2.3.2.so (0x1BBD0000)
==32192== TRANSLATE: 0x1BB123E0 redirected to 0x1B9077B0
==32192== TRANSLATE: 0x1BB0BBB0 redirected to 0x1B906510
==32192== TRANSLATE: 0x1BB0BD40 redirected to 0x1B906A82
==32192== TRANSLATE: 0x1BB0C2C0 redirected to 0x1B906EE2
==32192== TRANSLATE: 0x1BB0BE00 redirected to 0x1B906FA1
==32192== TRANSLATE: 0x1BA422D0 redirected to 0x1B90669A
cd ../..
# Reboot E5810
setIocLogDisable 0
iocInit
Starting iocInit
==32192== TRANSLATE: 0x1BA42410 redirected to 0x1B9068F8
==32192== TRANSLATE: 0x1BA40D00 redirected to 0x1B906C26
==32192== Mismatched free() / delete / delete []
==32192== at 0x1B906CA8: operator delete(void*) (vg_replace_malloc.c:155)
==32192== by 0x8058AC2: StreamBuffer::grow(long) (StreamBuffer.cc:103)
==32192== by 0x805AFDE: StreamProtocolParser::readToken(StreamBuffer&, char const*, bool) (StreamProtocol.cc:538)
==32192== by 0x805B52F: StreamProtocolParser::parseValue(StreamBuffer&, bool) (StreamProtocol.cc:602)
==32192== by 0x805A2F6: StreamProtocolParser::parseProtocol(StreamProtocolParser::Protocol&, StreamBuffer*) (StreamProtocol.cc:406)
==32192== by 0x805A6BA: StreamProtocolParser::parseProtocol(StreamProtocolParser::Protocol&, StreamBuffer*) (StreamProtocol.cc:370)
==32192== by 0x80598B8: StreamProtocolParser::StreamProtocolParser(_IO_FILE*, char const*) (StreamProtocol.cc:73)
==32192== by 0x8059E9E: StreamProtocolParser::readFile(char const*) (StreamProtocol.cc:201)
==32192== by 0x8059BF7: StreamProtocolParser::getProtocol(char const*, StreamBuffer const&) (StreamProtocol.cc:135)
==32192== by 0x8063A1B: StreamCore::parse(char const*, char const*) (StreamCore.cc:216)
==32192== by 0x8056F9A: Stream::initRecord() (StreamEpics.cc:607)
==32192== by 0x8055DAF: streamInitRecord (StreamEpics.cc:415)
==32192== Address 0x1BCC2890 is 0 bytes inside a block of size 128 alloc'd
==32192== at 0x1B906985: operator new[](unsigned) (vg_replace_malloc.c:138)
==32192== by 0x8058A6D: StreamBuffer::grow(long) (StreamBuffer.cc:97)
==32192==
==32192== by 0x805BEA4: StreamProtocolParser::Protocol::Variable::~Variable() (StreamProtocol.cc:714)
==32192== by 0x805C72A: StreamProtocolParser::Protocol::~Protocol() (StreamProtocol.cc:769)
==32192== by 0x8063A75: StreamCore::parse(char const*, char const*) (StreamCore.cc:228)
==32192== by 0x8053DDC: initRecord (devaiStream.c:77)
==32192== by 0x80A5949: init_record (aiRecord.c:143)
==32192== by 0x80BF59D: initDatabase (iocInit.c:351)
==32192== by 0x80BF0CF: iocInit (iocInit.c:107)
==32192== by 0x80BEF78: iocInitCallFunc (dbAccessRegister.c:69)
==32192== by 0x80BC8EC: iocshBody (iocsh.cpp:743)
==32192== Address 0x1BCCA270 is 0 bytes inside a block of size 128 alloc'd
==32192== by 0x80589D2: StreamBuffer::init(void const*, long) (StreamBuffer.cc:44)
==32192== by 0x805BD71: StreamProtocolParser::Protocol::Variable::Variable(StreamProtocolParser::Protocol::Variable const&) (StreamBuffer.h:61)
==32192== by 0x805C448: StreamProtocolParser::Protocol::Protocol(StreamProtocolParser::Protocol const&, StreamBuffer&, int) (StreamProtocol.cc:744)
==32192== by 0x805A0A3: StreamProtocolParser::getProtocol(StreamBuffer const&) (StreamProtocol.cc:239)
==32192== by 0x8059C0E: StreamProtocolParser::getProtocol(char const*, StreamBuffer const&) (StreamProtocol.cc:142)
==32192==
==32192== by 0x8058EEB: StreamBuffer::replace(long, long, void const*, long) (StreamBuffer.cc:212)
==32192== by 0x805E5AF: StreamProtocolParser::Protocol::compileString(StreamBuffer&, char const*&, FormatType, StreamProtocolParser::Client*, int) (StreamBuffer.h:145)
==32192== by 0x8063F53: StreamCore::compileCommand(StreamProtocolParser::Protocol*, StreamBuffer&, char const*, char const*&) (StreamCore.cc:295)
==32192== by 0x8060124: StreamProtocolParser::Protocol::compileCommands(StreamBuffer&, char const*&, StreamProtocolParser::Client*) (StreamProtocol.cc:1622)
==32192== by 0x805D4CD: StreamProtocolParser::Protocol::getCommands(char const*, StreamBuffer&, StreamProtocolParser::Client*) (StreamProtocol.cc:924)
==32192== by 0x8063DDC: StreamCore::compile(StreamProtocolParser::Protocol*) (StreamCore.cc:274)
==32192== by 0x8063A30: StreamCore::parse(char const*, char const*) (StreamCore.cc:222)
==32192== Address 0x1BCCD5B0 is 0 bytes inside a block of size 128 alloc'd
==32192== by 0x8058E55: StreamBuffer::replace(long, long, void const*, long) (StreamBuffer.cc:205)
==32192==
==32192== by 0x805BECB: StreamProtocolParser::Protocol::Variable::~Variable() (StreamProtocol.cc:715)
==32192== Address 0x1BCD1D70 is 0 bytes inside a block of size 128 alloc'd
==32192== by 0x8053BFC: initRecord (devaoStream.c:78)
==32192== by 0x80A6C0C: init_record (aoRecord.c:140)
==32192==
==32192== by 0x805F318: StreamProtocolParser::Protocol::compileString(StreamBuffer&, char const*&, FormatType, StreamProtocolParser::Client*, int) (StreamProtocol.cc:1380)
==32192== by 0x8054719: initRecord (devmbbiStream.c:117)
==32192== by 0x80B0E07: init_record (mbbiRecord.c:139)
==32192== Address 0x1C06D170 is 0 bytes inside a block of size 128 alloc'd
==32192== by 0x8058C3E: StreamBuffer::append(void const*, long) (StreamBuffer.cc:126)
==32192== by 0x805F97B: StreamProtocolParser::Protocol::compileFormat(StreamBuffer&, char const*&, FormatType, StreamProtocolParser::Client*) (StreamProtocol.cc:1603)
==32192== by 0x805E544: StreamProtocolParser::Protocol::compileString(StreamBuffer&, char const*&, FormatType, StreamProtocolParser::Client*, int) (StreamProtocol.cc:1115)
==32192==
==32192== Thread 3:
==32192== Use of uninitialised value of size 4
==32192== at 0x1BAF218B: _IO_vfscanf (in /lib/tls/libc-2.3.2.so)
==32192== by 0x1BAFD72C: vsscanf (in /lib/tls/libc-2.3.2.so)
==32192== by 0x1BAF880C: sscanf (in /lib/tls/libc-2.3.2.so)
==32192== by 0x8061663: StdCharsetConverter::scanString(StreamFormat const&, char const*, char*, unsigned) (StreamFormatConverter.cc:409)
==32192== by 0x8067217: StreamCore::matchInput() (StreamFormatConverter.h:68)
==32192== by 0x8065C6E: StreamCore::readCallback(StreamIoStatus, void const*, long) (StreamCore.cc:1009)
==32192== by 0x806A79E: AsynDriverInterface::readHandler() (StreamBusInterface.h:111)
==32192== by 0x806BC6B: handleRequest (AsynDriverInterface.cc:1278)
==32192== by 0x807C7DA: portThread (asynManager.c:777)
==32192== by 0x814541B: start_routine (osdThread.c:320)
==32192== by 0x1B92DB62: start_thread (in /lib/tls/libpthread-0.60.so)
==32192== by 0x1BB72189: clone (in /lib/tls/libc-2.3.2.so)
==32192==
==32192== Process terminating with default action of signal 11 (SIGSEGV)
==32192== Bad permissions for mapped region at address 0x8054585
==32192==
==32192== ERROR SUMMARY: 30 errors from 6 contexts (suppressed: 27 from 1)
==32192==
==32192== 1 errors in context 1 of 6:
==32192==
==32192== 1 errors in context 2 of 6:
==32192== Thread 1:
==32192==
==32192== 4 errors in context 3 of 6:
==32192==
==32192== 7 errors in context 4 of 6:
==32192==
==32192== 8 errors in context 5 of 6:
==32192==
==32192== 9 errors in context 6 of 6:
--32192--
--32192-- supp: 27 Ugly strchr error in /lib/ld-2.3.2.so
==32192==
==32192== IN SUMMARY: 30 errors from 6 contexts (suppressed: 27 from 1)
==32192==
==32192== malloc/free: in use at exit: 477440 bytes in 10433 blocks.
==32192== malloc/free: 10879 allocs, 446 frees, 586759 bytes allocated.
==32192==
==32192== searching for pointers to 10433 not-freed blocks.
==32192== checked 4513024 bytes.
==32192==
==32192== LEAK SUMMARY:
==32192== definitely lost: 60 bytes in 3 blocks.
==32192== possibly lost: 2308 bytes in 60 blocks.
==32192== still reachable: 475072 bytes in 10370 blocks.
==32192== suppressed: 0 bytes in 0 blocks.
==32192== Use --leak-check=full to see details of leaked memory.
--32192-- TT/TC: 0 tc sectors discarded.
--32192-- 15668 tt_fast misses.
--32192-- translate: new 12304 (244384 -> 3046173; ratio 124:10)
--32192-- discard 0 (0 -> 0; ratio 0:10).
--32192-- chainings: 9309 chainings, 0 unchainings.
--32192-- dispatch: 16936242 jumps (bb entries); of them 2652525 (15%) unchained.
--32192-- 349/28852 major/minor sched events.
--32192-- reg-alloc: 2640 t-req-spill, 533407+19152 orig+spill uis,
--32192-- 65985 total-reg-rank
--32192-- sanity: 350 cheap, 14 expensive checks.
--32192-- ccalls: 56065 C calls, 52% saves+restores avoided (172622 bytes)
--32192-- 79435 args, avg 0.86 setup instrs each (22208 bytes)
--32192-- 0% clear the stack (167703 bytes)
--32192-- 20900 retvals, 29% of reg-reg movs avoided (11918 bytes)
zsh: 32192 segmentation fault valgrind -v ../../bin/linux-x86/SIOC6CP st.cmd > out 2>& 1
- Re: Asyn/VXI-11 problems Benjamin Franksen
- Asyn/VXI-11 problems Benjamin Franksen
- RE: Asyn/VXI-11 problems Jeff Hill
- Re: Asyn/VXI-11 problems Eric Norum
Re: confusion with config dir in base Geoff Savage
Use of waveform records Touchard Dominique
<2007>
<2007>
