1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Asyn/VXI-11 problems
To: <[email protected]>
Cc: [email protected]
Date: Tue, 18 Sep 2007 08:59:16 -0600
Hi Ben,
You might try commenting out iocInit in the startup script, and then after
the IOC boots up type "sp iocInit". When it fails type "tt <task id>" to get
the stack trace. If that doesn't help you might also build for debugging and
attach the Tornado debugger to the IOC.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Benjamin Franksen
> Sent: Tuesday, September 18, 2007 7:32 AM
> To: [email protected]
> Subject: Asyn/VXI-11 problems
> Hi,
> we have trouble trying to control a scope (Tektronix DPO7254) via VXI-
> 11. It
> started after the scope's firmware was upgraded to fix some (unrelated)
> bug. However, the side-effect is that our IOC (linux) now crashes:
> #!../../bin/linux-x86/SIOC3CP
> # Change to top directory
> cd ../..
> ########################################################### Set up
> Environment
> epicsEnvSet IOC SIOC3CP
> epicsEnvSet LOG_DIR /opt/IOC/log
> epicsEnvSet EPICS_CA_PUT_LOG_INET 192.168.48.97
> epicsEnvSet STREAM_PROTOCOL_PATH db
> ############################################## Register all support
> components
> dbLoadDatabase dbd/SIOC3CP.dbd 0 0
> SIOC3CP_registerRecordDeviceDriver pdbbase
> ############################################################ Configure
> drivers
> # Configure asyn vxi-11 driver for DPO7254 device
> vxi11Configure L1 SCOPE1ZCP.mlscs.bessy.de 0 1 inst0 0 0
> asynSetTraceMask L1 -1 0x001f
> 2007/09/18 11:46:36.129 L1 -1 exception 3 occurred calling
> exceptionUser
> asynSetTraceIOMask L1 -1 0x0003
> 2007/09/18 11:46:36.129 L1 addr -1 queueRequest priority 3 not
> lockHolder
> 2007/09/18 11:46:36.129 L1 -1 exception 4 occurred calling
> exceptionUser
> asynSetOption L1 -1 rpctimeout 10
> lockHolder
> 2007/09/18 11:46:36.129 L1 addr -1 queueRequest priority 0 not
> lockHolder
> 2007/09/18 11:46:36.129 asynManager connect queueCallback port:L1
> 2007/09/18 11:46:36.129 L1 addr -1 vxiConnect
> 2007/09/18 11:46:36.129 L1 vxiConnectPort
> 2007/09/18 11:46:37.078 L1SRQ read error: Connection reset by peer
> 2007/09/18 11:46:37.078 L1SRQ vxiSrqThread terminating
> 2007/09/18 11:46:37.078 L1 vxiCreateIrqChannel VXI: channel not
> established
> (create_intr_chan)
> 2007/09/18 11:46:37.078 L1 Warning -- SRQ not operational.
> 2007/09/18 11:46:37.078 L1 -1 exception 0 occurred calling
> exceptionUser
> [1]    19274 segmentation fault  (; cd
> SIOC3CP/iocBoot/iocSIOC3CP; ./st.cmd; )
> Most probably the scope's new firmware is at fault for sending strange
> responses or something. Anyway, asyn should not crash, even if the
> device
> sends protocol errors.
> We have tried several versions of asyn (4-5, 4-6, 4-8) and several
> versions
> of stream (all versions from 1.1 to the latest snapshot) but they all
> display teh same or similar behavior. The base release is 3.14.8.2.
> Our main problem is that the scope should be operational at the start
> of
> next week when out shutdown ends. So, our next step will be to try
> communication via a GPIB gateway.
> Still, any advice on how to search for and maybe fix the error that
> lets
> asyn crash would be appreciated.
> Cheers
> Ben
> "Programming = Mathematics + Murphy's Law" (E.W.Dijkstra)
Re: Asyn/VXI-11 problems Eric Norum
Asyn/VXI-11 problems Benjamin Franksen
Prev: Beginer problem V . I . Stoica
Next: Re: Asyn/VXI-11 problems Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Asyn/VXI-11 problems Benjamin Franksen
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
