On Tuesday 09 October 2007 14:29, Dirk Zimoch wrote:
> Benjamin Franksen wrote:
> > Ok, I've found one bug in stream version 2-2 that leads to a crash. A
> > format of "%*[whatever>]"
> > gets converted internally to "%0[whatever>]%n" and then only /one/
> > pointer arg is provided to sscanf, instead of two. The method where
> > sscanf crashes is in StreamFormatConverter.cc:
> This bug had been reported to me by Emma Shepherd on August 27.
> A patch
> to fix this bug is available on the StreamDevice web page since the same
> day.
Hi Dirk
Sorry. I /did/ try the latest snapshot, that was the first thing I tried.
However, at this time I wasn't aware that we had two bugs at the same time,
the other one being in asyn/vxi-11. I learned that only later and it seems
I forgot to check with the snapshot version for a second time.
> If you find bugs, I can only fix them if you report them!
I thought posting on tech-talk would be enough to report a bug in
streamDevice. Should I CC you when reporting a bug?
Cheers
Ben
- Asyn/VXI-11 problems Benjamin Franksen
- Re: Asyn/VXI-11 problems Benjamin Franksen
- Re: Asyn/VXI-11 problems Dirk Zimoch
RE: Use of waveform records Mark Rivers
<2007>
Re: Asyn/VXI-11 problems J. Lewis Muir
<2007>
