1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VME Bus Error handling on MVME3100 and MVME6100 boards
Cc: [email protected]
Date: Mon, 28 Aug 2006 21:35:17 -0400
Andrew Johnson wrote:
> This doesn't mean that the existing drivers won't work; the vast
> majority of the time they will be fine.  They will not be robust in the
> presence of unexpected bus errors though.
And this problem rises only if the mvme6100 is used as a
system controller.   It will be fine if it's used a non system
controller.
Kate
Re: VME Bus Error handling on MVME3100 and MVME6100 boards Andrew Johnson
Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
Prev: Re: Is anyone running vxWorks on cPCI? Is so - which processor board? Any comments on it? Susanna Jacobson
Next: Re: VME Bus Error handling on MVME3100 and MVME6100 boards Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: VME Bus Error handling on MVME3100 and MVME6100 boards Andrew Johnson
