Kate Feng wrote:
Andrew Johnson wrote:
This doesn't mean that the existing drivers won't work; the vast
majority of the time they will be fine. They will not be robust in the
presence of unexpected bus errors though.
And this problem rises only if the mvme6100 is used as a
system controller. It will be fine if it's used a non system
controller.
No, that is incorrect. The problem relates to the onboard interface
between the CPU, its local PCI bus and the PCI to VME bridge chip; it is
not at all related to whether the VME interface chip is acting as the
VMEbus system controller or not.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
- Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
- Re: VME Bus Error handling on MVME3100 and MVME6100 boards Andrew Johnson
RE: VME Bus Error handling on MVME3100 and MVME6100 boards Thompson, David H.
<2006>
<2006>
