1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: VME Bus Error handling on MVME3100 and MVME6100 boards
To: Andrew Johnson <[email protected]>, [email protected]
Date: Fri, 08 Sep 2006 08:49:00 -0400
Andrew Johnson wrote about mvme6100:
> The only sure-fire way around this problem is to check
> the Tempe chip's VMEbus Exception Attributes Register after every
> write operation and every read that returns an all-1s bit pattern
Just a clarification:
Should'nt most applications be terminated upon bus error ?
For those applications, it seems that the overhead for the
VME read/write is necessary to be considered only inside
the related ISRs or in the related non-ISR routines where
the interrupt has to be disabled, which is rare.
FYI, the following is the hardware timing sequence on bus error :
MV6436x PCI master termination :
If there is no target response to the initiated transaction
within four clock cycles (five clocks in case of DAC transaction),
the master issues a Master Abort event.  The master de-asserts
FRAME# and on the next cycle de-asserts IRDY#. Also, the Interrupt
Cause register's MMAbort bit is set and an interrupt is generated,
if not masked.
The master supports three types of target termination:
. Retry
. Disconnect
. Target Abort
If a target terminates a transaction with Disconnect, the Mv6436x master
re-issues the transaction from the point it was disconnected.
If a target terminates a transaction with Retry, the Mv6436x master
re-issues the transaction.
Andrew Johnson wrote about the Tsi148:
>The Tsi148 PCI Target never terminates a transaction with a
>Target-abort and SIGTA (Signalled Target Abort): The Tsi148 does not
>generate a target abort, therefore this bit is hard-wired to a logic 0.
In its user manual:
"Ihe target can terminate a transaction with a retry or a
disconnect. ......."
>When the VME Master encounters one of these conditions, any write data
>in the buffers is removed (flushed). If the transaction was a VMEbus read,
>the VME Master completes the Linkage Module command by
>filling the buffer with a data pattern of all ones.
"One of the conditions"  is "when a VME bus transfer initiated
by the VME master does not complete successfully".
Kate
Re: VME Bus Error handling on MVME3100 and MVME6100 boards Andrew Johnson
Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
Prev: Looking for an IOC for Wiener PL512 Bertrand H.J. Biritz
Next: Re: Looking for an IOC for Wiener PL512 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: VME Bus Error handling on MVME3100 and MVME6100 boards Kate Feng
Next: Re: VME Bus Error handling on MVME3100 and MVME6100 boards Andrew Johnson
