Rees, NP (Nick) wrote:
One of our problems is that on one of the boards the interrupt
acknowledge register is write only - so a read from it generates a bus
error, which isn't as pretty as it should be. I presume (from Andrews
email) that if we read a value from any other readable VME memory
location, that will flush the pipeline just as well. Is that correct?
Yup, that's what the book says and my experience has confirmed that.
You might want to check that all your VMEbus master windows are marked
as Guarded in the sysPhysMemDesc[] table too, since that's the mechanism
by which the CPU is told it can't reorder read and write I/O operations
within this memory range.
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
-- Albert Einstein
- RE: Dev lib off-board register access Rees, NP (Nick)
Re: Dev lib off-board register access Andrew Johnson
<2006>
<2006>
