Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: Dev lib off-board register access
To: Jukka Pietarinen <jukka.pietarinen@mrf.fi>
Cc: Eric Bjorklund <bjorklund@lanl.gov>, EPICS tech-talk <tech-talk@aps.anl.gov>
Date: Fri, 14 Jul 2006 12:03:06 -0500
Jukka Pietarinen wrote:
I believe it has to be the same register the write was targeted at. I
It shouldn't be - the Universe-2 User Manual says explicitly in section 2.3.3.4: "Any PCI master attempting coupled transactions is retried while the TXFIFO contains data." A read is always a coupled transaction, thus any CPU read from the VMEbus should cause a delay while the TXFIFO is drained. I conclude that your problem is most likely not caused by the Universe-2 chip itself.
And this is what I see on the bus, which is really not what I wanted:
Read from pEr->Control
Read from pEr->RamData
Write to pEr->Control
Write to pEr->RamAddr
Is your A16 master window marked as Guarded in the sysPhysMemDesc[] table (in sysLib.c)? I can't think of any other explanation for the behaviour you were seeing.
- Andrew
Not everything that can be counted counts,
and not everything that counts can be counted.
  -- Albert Einstein
Dev lib off-board register access Rees, NP (Nick)
Re: Dev lib off-board register access Dirk Zimoch
Re: Dev lib off-board register access Eric Bjorklund
Re: Dev lib off-board register access Kate Feng
Re: Dev lib off-board register access Jukka Pietarinen
Prev: RE: Dev lib off-board register access Rees, NP (Nick)
Next: Re: Dev lib off-board register access Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: Re: Dev lib off-board register access Jukka Pietarinen
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
