This is really a follow-up to the 2002 thread on PowerPC caching: That thread ended up talking about write posting through the VME bridge, I'm not sure whether it's the same thing you're talking about or not. At Diamond we use the mvme5500. It seems that every vxWorks driver we have will fall over at some point unless we are careful with memory caching. Very few EPICS drivers do this properly. However, on the mvme5500 if we precede every read with a cacheInvalidate and follow every write routine with a cacheFlush we don't seem to have any problems. Caching should only be an issue if you have two bus masters accessing the same area of memory; i.e. if there is a DMA controller or a second CPU involved in the I/O operation. Not many EPICS drivers actually use a DMA controller, so most drivers don't need to worry about cache coherency issues. There is an option in Marty Kraimer's Generic Transient Recorder support to make use of some BSP-supplied DMA routines that I wrote for the Universe-2 and VMEchip2 bridges. My implementation of this VME DMA support *should* perform the necessary cache manipulation operations at the appropriate time (the requirements are different on different boards though; most boards can do bus snooping, but some do not and require the driver to call cacheInvalidate() before reading and cacheFlush() after writing the shared area). Later, Rees, NP (Nick) wrote: Peter Denison gave me the following link to the Linux kernel sources which gives a reasonable description of sync, lwsync, eieio and wmb, rmb etc. Not necessarily, since sync is an expensive instruction on the PowerPC which you would really rather not execute if you can avoid it. A cacheFlush() will perform other instructions that ensure the cache area specified is definitely pushed out to memory before it returns, but that doesn't necessarily need a sync. Note that all the VMEbus windows should be marked as Non-Cacheable and Guarded in your BSP's sysPhysMemDesc[] table. The problem we have found with the 5500 is, I think, related to the problem outlined in the 2002 tech-talk thread. The processor MMU may know the VME memory isn't cached, but there is also a cache in the VME chip (why, I don't know) and that has to be forced as well. Ok, that's a different issue and not a cache; the Universe-2 VME bridge chip has a write pipeline which enables a PCI bus write cycle to complete before the matching VMEbus cycle does. Cycles on VMEbus are generally much slower than on the PCIbus, and there's no reason to hold up the processor just to wait for the cycle to complete, so the bridge chip has a write FIFO built into it that allows it to queue up a series of write operations. This speeds up the processor operation quite a bit, at the expense of having to be a little more careful in the software (and a loss of synchronization with VME Bus errors, but that's a slightly different topic). The bridge ensures that all pending VME write operations are performed before it will execute any subsequent VMEbus read, for which it has to delay the PCIbus cycle since it can't complete that without getting the read data from the VME cycle anyway. This ensures that the I/O cycles are still performed in the same order that the CPU requested them, but the timing may be different. Usually the different timing that doesn't matter, but there is one circumstance where it does - clearing interrupt requests from VME boards. Here an Interrupt Service Routine needs to ensure that any write cycle going to a VME slave board that causes it to deassert an IRQ line gets out to the board before we return from the ISR, otherwise nasty things happen. The way to guarantee this is to perform a dummy read from some register on the VME board at the end of the ISR, which pushes the VMEbus writes out and thus clears the IRQ condition. This should be sufficient to fix your problem; the cacheFlush and/or cacheInvalidate that you were calling were inserting a delay into the CPU instruction chain which was probably sufficient time for the VME write pipeline to flush itself naturally. Howere this is not guaranteed, so I suggest you fix these with the VME read instead. - Andrew -- Not everything that can be counted counts, and not everything that counts can be counted. -- Albert Einstein
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
