On Tue, 2005-10-11 at 16:25 +0200, Jens Eden wrote:Mark, It works for me, attached is a small code snippet (it's just a quick and very dirty hack, to show linking and running ca_array_get() returns ECA_GETFAIL) which you can compile with the following command (make sure MinGW is in your Path): g++ -o ca-test.exe ca-test.cpp D:\epics\base-3.14.5\lib\win32-x86\ca.lib You need the EPICS-dlls in your Path to run it. That's all I tried, so I don't know, if there are other issues with the two compilers if developing real world applications. Did you try to compile the GPLed version of Qt with MS C++? Jens ***************** #include <stdio.h> #ifdef __cplusplus extern "C" { #endif __stdcall int ca_context_create(int); __stdcall int ca_create_channel(char *, void *, void *, int, void *); __stdcall int ca_array_get( long, long, void *, void *); __stdcall int ca_pend_io( double); __stdcall int ca_flush_io(); #ifdef __cplusplus } #endif # define DBR_DOUBLE 6 int main(void) { int result; char *pvname="ringCurrent1"; char somespace[500]; void *mychid; double doubledata=1.234; mychid = (void *)somespace; result = ca_context_create(0); if (result != 1) { printf("CA error (%d) ca_context_create \n", result); return 1; } result = ca_create_channel(pvname, NULL, NULL, 0, mychid); if (result != 1) { printf("CA error (%d) ca_create_channel \n", result); return 1; } result = ca_flush_io(); if (result != 1) { printf("CA error (%d) ca_pend_io \n", result); return 1; } result = ca_pend_io(1.0); if (result != 1) { printf("CA error (%d) ca_pend_io \n", result); return 1; } result = ca_array_get(DBR_DOUBLE, 0, mychid, &doubledata); if (result != 1) { printf("CA error (%d) ca_array_get \n", result); // return 1; } result = ca_pend_io(1.0); if (result != 1) { printf("CA error (%d) ca_pend_io \n", result); return 1; } printf("value: %9.5g\n", doubledata); }
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
