1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Qt-compatible Channel Access lib
To: Mark Davis <[email protected]>
Cc: [email protected]
Date: Tue, 11 Oct 2005 16:25:54 +0200
Mark,
it is possible to link applications compiled with MinGW to
dll-Files compiled with MS Visual Studio.
So in theory it is possible to link your MinGW/QT-Application to Epics
base compiled with MS Visual C++.
In practice you get a lot of errors from MinGW, when including Epics
include-files and you cant' use modules which don't compile with
MS Visual C++ (e.g. asyn).
I don't know, if the GPLed version of QT can easily be compiled with
the free Microsoft Visual C++ Compiler, but this could be an option too.
The combination of QT and Eclipse with the C/C++-Plugin gives a very
nice cross-platform development tool, which could make it a candidate
for Epics Office.
Jens
Mark Davis wrote:
Has anyone done any work with Trolltech's Qt cross-platform classes and EPICS Channel Access?
I am about to begin development of a set of EPICS client applications using Qt so the applications can be compiled and run on workstations running Windows, Linux, and MacOS. I have done some poking around, and so far have failed to turn up any mention of use of the Channel Access libraries with Qt.
Have I overlooked something obvious? Anyone know of any effort on this front? Seems unlike I am the first to work on this.
Thanks in advance for any info.
Mark Davis, [email protected] <mailto:[email protected]>
Control Systems Software Engineer
National Superconducting Cyclotron Lab, MSU
Re: Qt-compatible Channel Access lib Ernest L. Williams Jr.
Qt-compatible Channel Access lib Mark Davis
Prev: CAEN V965 Q-ADC Sibley III, Coles
Next: Re: Qt-compatible Channel Access lib Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Qt-compatible Channel Access lib john sinclair
