1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: IP Carrier Board
To: <[email protected]>
Date: Tue, 11 Oct 2005 07:49:12 -0700
Hello,
Has anyone written drivers for some of the newer VME (not 64X) IP Carrier boards. It seems that there are at least one driver that Andrew recently wrote for the Tews TVME200 (aka VIPC626), so that board is an option. And using Andrews ip carrier generic software package writing the software for newer carrier boards should be relatively easy but if the work is already done, that's even easier and it would be great to take advantage of that work if possible. So if there are any drivers available or ip carrier boards that people can recommend please let me know. I've used SBC ip carriers before and they have been quite reliable, so that's the direction I'm leaning towards right nowunless someone has had good experience with other ip carrier board. Thanks for you help.
Some of the ip carriers we're looking at (but are not limited to) are:
 1) SBS VIPC627
 http://www.sbs.com/products/741/
 2) SBS VIPC8244
 http://www.slac.stanford.edu/grp/lcls/controls/global/subsystems/magnet/slaconly/SBS_datasheet_VIPC8244_DS.pdf
 3) SBS VIPC8243
 http://www.slac.stanford.edu/grp/lcls/controls/global/subsystems/magnet/slaconly/SBS_datasheet_VIPC8243_DS.pdf
 4) Xycom TVME200 (driver same as VIPC626)
http://www.xycomvme.com/folder.2004-06-24.1215397535/folder.2004-06-24.1723358754/tvme200_10.html/view?searchterm=TVME200
 5) SBS VIPC626-ET (Andrew Driver avail) http://www.sbs.com/products/480
  Kristi
IP Carrier Board - Linux Drivers for Hytec IP Cards Darrell Nineham
Prev: Re: Qt-compatible Channel Access lib Ernest L. Williams Jr.
Next: Re: Qt-compatible Channel Access lib Jens Eden
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: CAEN V965 Q-ADC Sibley III, Coles
Next: IP Carrier Board - Linux Drivers for Hytec IP Cards Darrell Nineham
