1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Asyn build under win32
To: "'Mark Rivers'" <[email protected]>, <[email protected]>
Date: Wed, 12 Oct 2005 10:18:03 +1000
Mark,
I now have EPICS base-3.14.6 and asyn-4.0 building under Cygwin thanks.
However, my application won't build and complains of undefined references to
various devGpib functions (even though I have added the device driver and
asyn libs in the relevant Makefiles).
Eg.
... undefined reference to `_devGpib_initAi'
<snip>
... undefined reference to `_devGpib_readSi'
Any tips please?
-----Original Message-----
Sent: 30 September 2005 10:35 PM
To: Marty Kraimer; Mark Bennett; [email protected]; [email protected]
Hi Mark,
asyn does not build under the win32-x86 architecture, for the reasons
you discovered.  It uses the termios API for serial ports, and that does
not seem to be available under native Windows.
I am running quite a few IOCs on Windows machines now, for controlling
Roper CCD detectors, XIA spectroscopy detectors, and running small
laboratories with RS-232 motor controllers.  I use the cygwin-x86
environment so that I can use asyn.
To develop applications with cygwin you need to install basic cygwin
plus "make", "gcc", "perl", "g++" and the "SUN rpc" package.  However,
to run an application that has been built statically with cygwin-x86 you
only need to install the basic cygwin package on the target machine, and
that takes about 2 minutes.  Really all it should need is to have
cygwin1.dll in your PATH on Windows.
With the exception of the message I posted to tech-talk yesterday about
some CA problems, I have had excellent experience with cygwin.  I think
the problems I had yesterday should be viewed as an anomaly, perhaps due
to an errant application.  Rebooting has fixed the problem, at least for
now.
Waveform soft record Emmanuel Mayssat
RE: Asyn build under win32 Mark Rivers
Prev: Re: Qt-compatible Channel Access lib Jens Eden
Next: IP Carrier Board - Linux Drivers for Hytec IP Cards Darrell Nineham
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Asyn build under win32 Mark Rivers
Next: Waveform soft record Emmanuel Mayssat
