It's just that it doesn't seem to make much sense to pass the I believe it's there for subroutines that want to cause asynchronous processing - if the user subroutine sets psub->pact true before returning because of a background I/O operation, it will need to call the record's process() routine again when that I/O operation is complete. Passing it into the init subroutine is simpler for the user than requiring them to look up the process routine than using a construct that may at one time have been (((struct rset*)psub->rset)->process)(psub); which is a bit ugly and complicated if someone is new to C programming. The cast is no longer needed, but it might have been back in the old GTACS days. - Andrew -- Edsger W. Dijkstra, 1930-2002: "The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offence."
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
