Dear Sir:
I have make the EPICS base on
Redhat6.2 successfully.
While downloading the vxWorks and EPICS database, the message
is like this:
iocInit
IocLogClient:EPICS environment variable "EPICS_IOC_LOG_INET"
undefined
iocLogClient:logging disabled
###@(#)EPICS IOC CORE
###@(#)Version R3.13.1..0$$Date:1998/11/19
16:18:25$$
Starting iocInit
I have define the environment in
.../EPICS/base/config/CONFIG_SITE_ENV, so I
add this line in CONFIG_SITE_ENV:
EPICS_IOC_LOG_INET=***.***.***.***
/* here is my IP address*/
then make the EPICS base again, and using makeBaseApp to have
a new application,
this time whiling loading , the message is:
iocInit
iocLogClient:unable to connect to Linux:7004 because
"error=0x39"
I am puzzled on this message, can anybody tell me what does
that error message mean?
And I have another question about the board Td4v(used in
Timing system)
This board uses A32/D32 mode, out CPU card is MVME162. and the
board's base address is
set to 0x21000000 . But after makeing the Device support and
downloading, it tells that
the board can't be found//thinkhard
Is there any confliction of the board base address settings?
Any suggestion is appreciated.
BTW: You are kindly enough if you can send a
copy to my mail box while repling this mail.
Thank you very much
Cheng Weixing from SSRF(Shanghai Synchrontron Radiation
Center),China
