Dear Shen Guobao, Bernhard Kuner from Bessy has kindly provided me with an up-to-date set of epics symbols for CapFast, included as an attachment to this message. This set does not include the corresponding CapFast menu, and I have not yet had time to add entries for the records that were new with release 3.13. I have therefore added as a second attachment an older menu. It is easy to add new entries to the menu: just include with any plain text editor the pair of lines like string :get eai text analog in (small) where "eai" is the filename of the symbol (i.e. ~p3/library/epics/eai.sym) and "analog in (small)" is the text to be displayed in the menu for that entry. (Note that I have renamed the file oldEPICS.MNU because I have already added a few items to my working copy.) If you have not met it before, the edif.tgz is a gzipped tar file. My version of tar recognizes these files and gunzips them automatically. Otherwise it might be useful to > mv edif.tgz edif.tar.gz ! gives it a more standard name > gunzip edif.tar.gz ! unpacks it to edif.tar > tar xvf edif.tar ! extracts all the files. Then copy all the symbol files into ~p3/library/lib. Save the to All of the *.sym files in edif. Copy oldEPICS.MNU to ~~p3/wcs/lib/EPICS.MNU. Included in the edif.tgz file is edb.def. CapFast includes a utility sch2edif that translates CapFast schematics into edif files. The EPICS utility e2db uses edb.def to translate the edif files into database files. You will need to edit E2DB_SYSFLAGS in /EPICS/base/config/CONFIG_SITE to point to the location of your edb.def file. If you have not already discovered this, e2db is NOT included in the EPICS base, but is available as an extension. The best place I am aware of to find this is the APS site http://www.aps.anl.gov/xfd/SoftDist/extensio.htm and copy over both files linked to in item 8: CAPFAST Source for CAPFAST extensions: "capfast_extensions_v_2_1_src.tar.gz": Includes db2capsym, dbst, e2db. 3/8/99 See also: "CAPFAST_README" (To find this page, start at the main APS epics site http://www.aps.anl.gov/epics/ and follow the links "Host Software" -> "Extensions Distribution".) I also found this to be one of the more awkward and confusing steps in my EPICS installation. There does not yet seem to be a site with a standard installation of the current EPICS symbols. Personally, I think the correct place for this would be the capfast_extensions_v_2_1_src.tar.gz file mentioned above, and that Phase3 should have a link to this page for the benefit of new EPICS installations. Good luck, Russell O. Redman -----Original Message----- From: Bernhard Kuner [mailto:[email protected]] Sent: Monday, December 18, 2000 1:01 AM To: [email protected] Subject: Capfast Library for EPICS Dear Mister Russel, here the Capfast library for epics-symbols as we use it here - mbbi direct included. -- ----------------------------------------------------------------------- Bernhard Kuner Company: Bessy GmbH Tel + 30 6392 4858 Albert Einstein Str. 15 Fax 4859 [email protected] D-12489 Berlin Attachment:
edif.tgz Attachment:
oldEPICS.MNU
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
