g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: "spinlock" API
To: Andrew Johnson <anj@aps.anl.gov>
Cc: core-talk@aps.anl.gov
Date: Mon, 11 Jun 2012 16:22:48 -0400
On 6/11/2012 12:06 PM, Andrew Johnson wrote:
On 2012-06-11 Michael Davidsaver wrote:
I used 'unsigned long' in the example, but the formal specification
would be:
typedef<unspecified>  epicsSpinKey;
Unfortunately the header does have to fully define the key type, since the
user code has to instantiate one of these to be able to take a lock.
By unspecified I mean only that the type aliased to epicsSpinKey is not part of the API and users should consider that it may change.
#define epicsSLLocalFlag(name) epicsSLFlag name = 0
It's quite valid to call a function to initialize something one of its
arguments points at; we do that all the time with calls to sscanf() for
example without it generating warnings.  I don't think the macro is necessary.
Sorry, wrong warning...  You are correct that the '=0' isn't needed
When I firsted implemented this with macros I was getting "usused variable" warnings so I wanted a way to make the flag variable disappear when not needed.
The current implementation for the thread pool:
#if defined(vxWorks) || defined(__rtems__)
#include "epicsInterrupt.h"
#define POOLFLAG(flag) int flag
#define LOCKPOOL(pP, pFlag) do{ *(pFlag) = epicsInterruptLock(); }while(0)
#define UNLOCKPOOL(pP, pFlag) do{ epicsInterruptUnlock(*(pFlag)); }while(0)
#else
#include "epicsMutex.h"
#define POOLFLAG(flag) do{}while(0)
#define LOCKPOOL(pP, pFlag) epicsMutexMustLock((pP)->guard)
#define UNLOCKPOOL(pP, pFlag) epicsMutexUnlock((pP)->guard)
#define POOLUSEMUTEX 1
#endif
where POOLUSEMUTEX  is used like
#ifdef POOLUSEMUTEX
    epicsMutexId guard;
#endif
A better thing to do might be
typedef void* epicsSpinId
#else
typedef epicsMutexID* epicsSpinId
#endif
I have a revised preference about names, to match other OSI APIs:
typedef struct epicsSpin * epicsSpinId;
Then replace all instances of epicsSpin * with epicsSpinId.
Ok.
Michael
Re: "spinlock" API Andrew Johnson
"spinlock" API Michael Davidsaver
Re: "spinlock" API Michael Davidsaver
Prev: Re: "spinlock" API Andrew Johnson
Next: Re: "spinlock" API Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
ANJ, 26 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
