g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: "spinlock" API
To: mdavidsaver@bnl.gov
Cc: core-talk@aps.anl.gov
Date: Fri, 8 Jun 2012 18:14:43 -0500
Hi Michael,
On 2012-06-08 Michael Davidsaver wrote:
> > Have you looked at the epicsAtomicLock() and epicsAtomicUnlock() routines
> > that Jeff uses in some of his epicsAtomic implementations?
> It looks like the current posix implementation uses a global lock
> similar to epicsInterrupt.  Do you see a way this could be avoided?
Ahh, that implementation is only used if the compiler does not support the
atomic operations directly, which is not what you want at all.  Sorry, I think
I pointed you up completely the wrong tree there.
> My goal for the thread pool implementation is to, as much as possible,
> allow two pools to function independently.  Having a global mutex used
> in the queuing and dequeuing processes seems a likely point of contention.
Agreed.  We do need a spinlock API in Base, and you are the first person to
publicly propose one, so at the moment you win, although I expect Jeff has
already developed one...
Looking back at your original proposal, I have some naming suggestions:
> struct epicsSL;
> typedef struct epicsSL epicsSL;
typedef struct epicsSpin epicsSpin;
> typedef unsigned long epicsSLFlag;
What actually gets stored in this (why is it a ULong)?  Part of me would like
to use the term "key" or maybe "state" instead of "flag", but that depends
what it's actually for.
typedef unsigned long epicsSpinKey;
> #define epicsSLLocalFlag(name) epicsSLFlag name = 0
Not keen, depends on answer above...
> epicsSL* epicsSLCreate()
> void epicsSLDestroy(epicsSL*);
epicsSpin* epicsSpinCreate(void);
void epicsSpinDestroy(epicsSpin*);
> void epicsSLLock(epicsSL*, epicsSLFlag*);
> int epicsSLTryLock(epicsSL*, epicsSLFlag*);
> void epicsSLUnlock(epicsSL*, epicsSLFlag*);
void epicsSpinLock(epicsSpin *, epicsSpinKey *);
int epicsSpinTry(epicsSpin *, epicsSpinKey *);
void epicsSpinUnlock(epicsSpin *, epicsSpinKey *);
We'll talk more on Monday...
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: "spinlock" API Michael Davidsaver
Re: "spinlock" API Andrew Johnson
Prev: Re: "spinlock" API Michael Davidsaver
Next: Re: "spinlock" API Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
ANJ, 26 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
