g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: "spinlock" API
To: mdavidsaver@bnl.gov
Cc: core-talk@aps.anl.gov
Date: Mon, 11 Jun 2012 16:16:19 -0500
Hi Michael,
On 2012-06-11 Michael Davidsaver wrote:
> A better thing to do might be
> #if defined(vxWorks) || defined(__rtems__)
> typedef void* epicsSpinId
> #else
> typedef epicsMutexID* epicsSpinId
> #endif
Can we design the default implementation to use atomic variables instead of
mutexes, unless there really is no alternative?  On a workstation OS the act
of taking or releasing a mutex always requires a context switch, whereas an
atomic operation does not.  Spin-lock operations are supposed to be lighter
than a mutex ones on SMP, and that aspect of your suggestion is bothering me.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: "spinlock" API Michael Davidsaver
Re: "spinlock" API Andrew Johnson
Prev: Re: "spinlock" API Michael Davidsaver
Next: Re: "spinlock" API Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
ANJ, 26 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
