Hi Michael,
On 2012-06-11 Michael Davidsaver wrote:
> I used 'unsigned long' in the example, but the formal specification
> would be:
> typedef <unspecified> epicsSpinKey;
Unfortunately the header does have to fully define the key type, since the
user code has to instantiate one of these to be able to take a lock.
> >> #define epicsSLLocalFlag(name) epicsSLFlag name = 0
> > Not keen, depends on answer above...
> The only use of this type is as a function local variable. This is an
> attempt to make this case more convenient. The zero assignment is meant
> to avoid compiler warnings about using of an uninitialized variable when
> passing the pointer to the lock() function.
It's quite valid to call a function to initialize something one of its
arguments points at; we do that all the time with calls to sscanf() for
example without it generating warnings. I don't think the macro is necessary.
I have a revised preference about names, to match other OSI APIs:
typedef struct epicsSpin * epicsSpinId;
Then replace all instances of epicsSpin * with epicsSpinId.
I just looked up spinLocks in the vxWorks 6.8 documentation, for comparison.
If possible we should try to design our API so that native APIs can be a
substituted using macros or inline functions where available.
Wind River provides 4 different spinlock types, in 3 libraries:
spinLockLib spinlock library
spinLockIsrNdLib fast, nondeterministic ISR spinlock library
spinLockNdTimedLib time limited spinlock library
The first library defines two types, ISR-callable (which masks interrupts on
the local CPU) and task-only. These are the functions they provide:
spinLockIsrInit( ) initialize an ISR-callable spinlock
spinLockIsrTake( ) take an ISR-callable spinlock
spinLockIsrGive( ) release an ISR-callable spinlock
spinLockIsrHeld( ) is an ISR-callable spinlock held by the current CPU?
These all take just spinlockIsr_t *pLock
spinLockTaskInit( ) initialize a task-only spinlock
spinLockTaskTake( ) take a task-only spinlock
spinLockTaskGive( ) release a task-only spinlock
These all take just spinlockTask_t *pLock
spinLockIsrNdInit( ) initialize a non-deterministic ISR spinlock
spinLockIsrNdTake( ) take a non-deterministic ISR spinlock
spinLockIsrNdGive( ) release a non-deterministic ISR spinlock
These use an int key as well as spinlockIsrNd_t *spin
spinLockNdTimedInit( ) initialize a timed spinlock
spinLockNdTimedTake( ) take a timed spinlock
spinLockNdTimedGive( ) give a timed spinlock
spinLockNdTimedPrevOwnerGet( ) get ID of the previous owner of spinlock
These are a lot more complicated...
We should be able to implement your API using either the spinLockIsr or
spinLockIsrNd types. I would need to read more to work out the difference
between them though.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Re: "spinlock" API Michael Davidsaver
- "spinlock" API Michael Davidsaver
- Re: "spinlock" API Andrew Johnson
<2012>
<2012>
