Ralph Lange wrote:
The two -Wl options (compiled-in locations for shared libraries) are
correct:
One location is the generic location, where the EPICS Base will be
installed. The other is the local directory, i.e. the location of the
Base that I'm currently linking against. This makes sure that the
libraries are found on the development machine as well as on the runtime
system (where the Base will be installed at the generic location).
Shouldn't your 'generic' path be pointing to an empty or non-existent
directory though when you're compiling? You should change that path to
/opt/epics/R3.14.8/support/base/3-14-8-0 or similar, so it will never
try to link against old libraries. The -L option *should* be pointing
to your local build tree since that gets used at compile time, but at
runtime you also want it to search the install location.
- Andrew
* * Matt Santos / / Leo McGarry * * For a Brighter America * *
- Re: Build system problem Ralph Lange
- mrkSoftTest doesn't compile Ralph Lange
- Re: mrkSoftTest doesn't compile Marty Kraimer
- Build system problem (was: mrkSoftTest doesn't compile) Ralph Lange
RE: R3.14.8 Status/logClient patch Jeff Hill
Re: R3.14.8 Status/logClient patch Benjamin Franksen
<2005>
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
