Right.
But:
The generic path definition is built from the definitions in
configure/CONFIG_BASE_VERSION (see
configure/os/CONFIG_SITE.Common.hpux-parisc), and these still have the
old numbers. Should the definitions in CONFIG_BASE_VERSION be changed in
the CVS repository immediately *after* a release instead of *before*
releasing?
For now, I get the correct generic path as soon as 3.14.8 is released,
as Janet is changing the numbers as part of creating the release.
So we do have an agreement that the -L option should always point to the
loacl build tree. Good.
I don't feel comfortable enough (yet) with the new configure files to
apply a fix. I guess that something has to be changed with the
definition of SHRLIB_DEPLIB_DIRS in
configure/os/CONFIG.Common.UnixCommon, but I'm not sure what exactly is
wrong there.
Ralph
Andrew Johnson wrote:
Ralph Lange wrote:
The two -Wl options (compiled-in locations for shared libraries) are
correct:
One location is the generic location, where the EPICS Base will be
installed. The other is the local directory, i.e. the location of the
Base that I'm currently linking against. This makes sure that the
libraries are found on the development machine as well as on the
runtime system (where the Base will be installed at the generic
location).
Shouldn't your 'generic' path be pointing to an empty or non-existent
directory though when you're compiling? You should change that path
to /opt/epics/R3.14.8/support/base/3-14-8-0 or similar, so it will
never try to link against old libraries. The -L option *should* be
pointing to your local build tree since that gets used at compile
time, but at runtime you also want it to search the install location.
- Andrew
- mrkSoftTest doesn't compile Ralph Lange
- Re: mrkSoftTest doesn't compile Marty Kraimer
- Build system problem (was: mrkSoftTest doesn't compile) Ralph Lange
- Re: Build system problem Andrew Johnson
RE: R3.14.8 Status/logClient patch Jeff Hill
Re: mrkSoftTest doesn't compile Ralph Lange
<2005>
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
