Subject: |
Build system problem (was: mrkSoftTest doesn't compile) |
Ralph Lange <[email protected]> |
To: |
EPICS Core Talk <[email protected]> |
Date: |
Wed, 16 Nov 2005 17:11:19 +0100 |
The two -Wl options (compiled-in locations for shared libraries) are
correct:
One location is the generic location, where the EPICS Base will be
installed. The other is the local directory, i.e. the location of the
Base that I'm currently linking against. This makes sure that the
libraries are found on the development machine as well as on the runtime
system (where the Base will be installed at the generic location).
There is one major problem, though:
The library path for the current linker command (-L) is set to the
generic location!
That means, that even if I'm pointing my local configure/RELEASE to my
base under test (/home/unix/lange/work/epics/APS/epics/base/3-14-X), any
executables will be linked against the generic libraries in the
.../3-14-7-0 location, which are the old ones.
I assume that - while keeping both locations in the -Wl seems correct -
the library path for the linker command should always be the location
directly from the EPICS_BASE location set in configure/RELEASE
Janet, would you agree?
Ralph
Marty Kraimer wrote:
It works for me on my version of Linux. Mine, however, is getting old
uranus% cat /proc/version
Linux version 2.4.21-9.0.1.EL ([email protected]) (gcc
version 3.2.3 20030502 (Red Hat Linux 3.2.3-26)) #1 Mon Feb 9 22:44:14
EST 2004
In
/usr/bin/g++ -o common
-L/opt/epics/R3.14.7/support/base/3-14-7-0/lib/linux-x86/
-Wl,-rpath,/opt/epics/R3.14.7/support/base/3-14-7-0/lib/linux-x86
-Wl,-rpath,/home/unix/lange/work/epics/APS/epics/base/3-14-X/lib/linux-x86
Why are there two "-W1" pointing to different versions of base?
Marty
Ralph Lange wrote:
Marty,
mrkSoftTest doesn't compile aymore (neither on HP nor on Linux):
aCC -o access -L/opt/epics/R3.14.7/base/3-14-7-0/lib/hpux-parisc/
-AA -mt
-Wl,+b/home/unix/lange/work/epics/APS/epics/base/3-14-X/lib/hpux-parisc:/home/unix/lange/work/epics/APS/epics/extensions/lib/hpux-parisc:/opt/epics/R3.14.7/base/3-14-7-0/lib/hpux-parisc,+s
access_registerRecordDeviceDriver.o asinittest.o asTest.o
asTrapWriteTest.o accessMain.o -lrecIoc -lsoftDevIoc -liocsh
-lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc
-ldbStaticIoc -lca -lCom
/usr/ccs/bin/ld: Unsatisfied symbols:
pvar_int_dbRecordsOnceOnly (first referenced in
access_registerRecordDeviceDriver.o) (data)
On Linux:
-Wl,-rpath,/home/unix/lange/work/epics/APS/epics/extensions/lib/linux-x86
devAiAsyn.o common_registerRecordDeviceDriver.o commonMain.o
-ltestDevIoc -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc -lrsrvIoc
-ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
common_registerRecordDeviceDriver.o(.text+0x4a1): In function
`__static_initialization_and_destruction_0':
/net/unix/mnt/csr-home/lange/work/epics/APS/epics/mrkSoftTest/common/src/O.linux-x86/common_registerRecordDeviceDriver.cpp:264:
undefined reference to `pvar_int_dbRecordsOnceOnly'
I don't see any changes in mrkSoftTest, though. Strange. I'm pretty
sure you know faster than me what's wrong ...
Ralph
- Re: Build system problem Andrew Johnson
- mrkSoftTest doesn't compile Ralph Lange
- Re: mrkSoftTest doesn't compile Marty Kraimer
RE: dbEvent.c line 665 Jeff Hill
<2005>
<2005>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
